help with h22 redline
Old Sep 29, 2005 | 07:36 PM
akkord94's Avatar
Default help with h22 redline
my 95 accord ex is hitting redline at 6600 what is the problem
Old Sep 29, 2005 | 07:51 PM
=Hmong='s Avatar
Default Re: help with h22 redline (akkord94)
make sure you car is at normal operating temperature.
Old Sep 29, 2005 | 07:58 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akkord94 &raquo;</TD></TR><TR><TD CLASS="quote">my 95 accord ex is hitting redline at 6600 what is the problem </TD></TR></TABLE>
What ECU are you using?
Old Sep 30, 2005 | 08:13 AM
972drcordex's Avatar
Id like to know the same thing I just got mine done and the only thing I have left to do is hook up the knock sensor and the vtec solenoid. I was running with ou t those two things hooked up and it was cutting off around 6600 as well. Not to thread jack but would the hooking up of the knock sensor and solenoid have any kind of effect on that? I am using a obd 2- ob1 conversion harness with a jdm 94 prelude ecu. Thanks
Old Sep 30, 2005 | 08:48 AM
h22accordfodo's Avatar
Default Re: help with h22 redline (972drcordex)
if your using the stock accord tach it is off a bit, i had to get a 5" autometer to get accurate tach info
Old Sep 30, 2005 | 01:53 PM
anyone else?
Old Sep 30, 2005 | 03:11 PM
akkord94's Avatar
Default Re: help with h22 redline (h22accordfodo)
i got a afc so i can see my shifts
Old Sep 30, 2005 | 11:42 PM
ricepicker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 972drcordex &raquo;</TD></TR><TR><TD CLASS="quote">Id like to know the same thing I just got mine done and the only thing I have left to do is hook up the knock sensor and the vtec solenoid. I was running with ou t those two things hooked up and it was cutting off around 6600 as well. Not to thread jack but would the hooking up of the knock sensor and solenoid have any kind of effect on that? I am using a obd 2- ob1 conversion harness with a jdm 94 prelude ecu. Thanks</TD></TR></TABLE>
Ummm why do you think it's called a VTEC Solenoid.......... But yes, Those are vital components to not have your car run like ****.
But anyways Akkord94 are you having any Check Engine Lights?
Old Oct 1, 2005 | 12:43 PM
akkord94's Avatar
Default Re: help with h22 redline (ricepicker)
yea i am having acheck engine light but they said it was my o2 sensor
Old Oct 1, 2005 | 12:45 PM
ricepicker's Avatar
Loop the diagnostic plug under the dash and give us a number. It'll help us help you.
Old Oct 1, 2005 | 04:32 PM
akkord94's Avatar
found the code it's a 12 and 21
12 egr
21 vtec solonoid
ricepicker is a great guy lots of help. wish there was more people like him
whoknew
May 4, 2009 10:33 PM
viet_tec
Aug 15, 2006 02:52 AM
JDM-accord_94
Nov 21, 2004 08:46 PM
burple accord
Feb 4, 2004 02:32 PM
