zc engine
Old Sep 29, 2005 | 07:26 PM
x91civichatch's Avatar
Default zc engine
where could i get a zc engine and how hard would it be to swap it into a 91 STD hatch?
Old Sep 30, 2005 | 09:10 AM
Str84wardJDM's Avatar
Default Re: zc engine (x91civichatch)
Go to http://www.soshinusa.com I have bought many of ZC's there and have never had a problem. SOHC ZC about $250 they are used japanese motors with less than about 50,000-60,000 miles. Good Luck
Old Sep 30, 2005 | 09:12 AM
R_type's Avatar
Default Re: zc engine (Str84wardJDM)
oh man.....
Old Sep 30, 2005 | 02:41 PM
virginia_dude's Avatar
I bought my original DOHC ZC and trans , and later my EF9 Sir Halfcut from these guys...good people in my book.
http://WWW.NOYANUSA.COM
Old Sep 30, 2005 | 05:06 PM
cmyrex's Avatar
hmotors is a good place also
Old Sep 30, 2005 | 05:09 PM
kulangot's Avatar
Default Re: zc engine (cmyrex)
https://honda-tech.com/zerothread?id=1325660
this is a good place to start..
Old Sep 30, 2005 | 08:18 PM
chupacabrah's Avatar
Default Re: zc engine (kulangot)
the swap is easy. i just put a dohc zc in my 91 std.
i got my engine from hmotorsonline (but you can find them cheaper).
basically, you just do the mpfi conversion, get a ecu, and drop it in.
use your stock axles and linkage.
easy stuff
i love my zc now
Old Oct 9, 2005 | 11:12 AM
user 98292739's Avatar
i would go with http://www.hmotorsonline.com too swap isnt hard. you have to wire for MPFI thats probally the hardest part. other then that its unbolt, pull, fit, bolt, blam your done a half a days job
Old Oct 9, 2005 | 12:44 PM
Idiotboy's Avatar
Easy swap, pay attention to the vacume lines running to the MAP sensor. Have fun!
Old Oct 10, 2005 | 09:46 PM
Default Re: zc engine (Idiotboy)
I got my engine from hmotorsonline....but i wouldnt recommend them again. their customer service sucks!
IAS can get you a zc just as cheap.
so can noyan, probably. (invirginia)
Old Oct 10, 2005 | 10:51 PM
rolledthatho's Avatar
so easy it took 2 weeks to do, HA and you forgot to mention he will need a diff tranny SI, and to re calibrate his TPS and the wiring which seems horrible
Old Oct 10, 2005 | 11:07 PM
NikoZai's Avatar
Default Re: (rolledthatho)
Wiring Solved = http://www.rywire.com
Engine Solved = http://www.hmotorsonline.com
Easy.
Old Oct 11, 2005 | 06:56 AM
ek_slut's Avatar
hmotors is the place to go
Old Oct 11, 2005 | 11:06 AM
Default Re: zc engine (chupacabrah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chupacabrah &raquo;</TD></TR><TR><TD CLASS="quote">I got my engine from hmotorsonline....but i wouldnt recommend them again. their customer service sucks!
so can noyan, probably. (invirginia)</TD></TR></TABLE>
they had great customer service to me. you cant act like the customer is always right with him. play it his way and he will play it your way. i had a clutch problem he sent me a new clutch. i know of a guy who had a head gasket problem. he sent him 300 bucks for labor and a mugen head gasket. so HMO is still the best i have seen and heard and witnessed. other places i have heard bad stuff about.
Old Oct 11, 2005 | 02:24 PM
jdmef1991's Avatar
I'm a Jackass
there's a place in Lynwood CA. that sells the DOHC ZC for $400 you get to pick whichever motor suits you the link is http://www.kwcengine.com oh the place is called WATANABE
Old Oct 12, 2005 | 11:17 AM
he can use his std tranny he doesnt need an Si tranny. Si would just greatly improve performance
Old Oct 15, 2005 | 08:23 PM
88backhatch's Avatar
Default Re: (Rexified)
i ordered my DOHC ZC thursday and Steve was a cool guy, i had no problems, except they didnt have the pm7 in stock and i should get the motor somehwhere around the end of next week or the week after that, thumbs up HMOTORS
svacca1
Sep 15, 2007 06:52 PM
Project91Hatch
18
Feb 20, 2006 06:27 AM
vti_shifter
Jul 17, 2005 08:31 AM
Horse_Balls
Jun 18, 2004 01:31 PM
Ronin Panda
32
Apr 23, 2003 06:45 PM
