OBDO-OBD1 problem
Old Sep 29, 2005 | 06:18 PM
fatboyford's Avatar
Default OBDO-OBD1 problem
Hey guys. I'm having trouble getting my CRX switched from OBDO to OBD1. I bought an OBD1 ECU and the wiring conversion harness and when I plug everything up my car will not start. What am I missing?
Old Sep 29, 2005 | 07:36 PM
CRX_Control's Avatar
Default Re: OBDO-OBD1 problem (fatboyford)
ground wires all in place?? any power?does it crank? fuel pump prime?
Old Sep 29, 2005 | 07:37 PM
RA122324's Avatar
Where'd you buy the conversion harness from?
Old Sep 29, 2005 | 07:43 PM
EG8R's Avatar
Default Re: (knwldge54)
Did you get an OBD1 distributor?
Old Sep 29, 2005 | 07:44 PM
fatboyford's Avatar
bought the harness and ECU from ECUtuning.com When I bought in to this I thought it was a plug and play deal. I'm currently into it for $300.00 and car just turns over. No spark, no fuel, no nothing.
Old Sep 29, 2005 | 07:46 PM
EG8R's Avatar
Default Re: (fatboyford)
It is plug and play when you have all the right parts
Conversion Harness
OBD1 ECU
OBD1 Distributor
4 wire O2 sensor
I think thats all thats needed...
Old Sep 29, 2005 | 07:51 PM
fatboyford's Avatar
Where is a good place to buy an OBD1 distributer and 4 wire O2 sensor?
Old Sep 29, 2005 | 07:55 PM
EG8R's Avatar
The wreckers? That's all I can suggest if you don't wanna spend much money...
Old Sep 29, 2005 | 08:45 PM
krazie1's Avatar
BANNED
Default Re: (skelly ed666)
or u can try looking in the classifieds
Old Sep 30, 2005 | 01:48 AM
NikoZai's Avatar
Default Re: (krazie1)
http://www.rywire.com
Cheap place for a Factory Denso 4-wire 02 and our distributor prices aren't bad either
O2 - $75
TD-44U - $235
free shipping
Yes using a OBD0 Distributor will definately cause your car not to run
Rywire has OBD0 to OBD1 Distributor Adapters too
Hope that ECU jumper wasn't over $110
Old Sep 30, 2005 | 03:31 AM
Blown90hatcH's Avatar
Default Re: (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">http://www.rywire.com
O2 - $75
TD-44U - $235
free shipping
Hope that ECU jumper wasn't over $110</TD></TR></TABLE>
Werd. I don't understand why people try and short change a few bucks. Mil-spec JKOBD OBD0-1 conversion harness. The original H-T maker. Simple instructions.
Post up a picture of the harness and the instructions too.
Old Sep 30, 2005 | 03:33 AM
RA122324's Avatar
Distributor King gives discounts to Honda-Tech members too.
I say revert back to OBD0 until you have everything you need.
Old Sep 30, 2005 | 03:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knwldge54 &raquo;</TD></TR><TR><TD CLASS="quote">Distributor King gives discounts to Honda-Tech members too.
I say revert back to OBD0 until you have everything you need.</TD></TR></TABLE>
On a note about distributor king distributors. The colors are not OEM colors. When using my harness, I have figured out the colors to match. Not sure about others.
Zack Gunther
13
Aug 5, 2014 09:04 AM
igotthaspirit
Feb 1, 2012 04:39 PM
jarhead90crx
12
Aug 5, 2011 07:06 AM
Fezzie
Aug 31, 2006 05:40 AM
mrx
Mar 12, 2005 01:06 PM
