Turbo B16 part 2
After selling my white hatch i've moved on to building this kit piece by piece for the new hatch. I have everything but a turbo now (one I bought ended up being to costly to repair) so hopefully in a few months I can save up enough to buy one and get it running
Unless someone has a nice 5-bolt exhaust turbo they would like to donate
Here is some pics of it test fitting the IC and piping and the other parts..
Modified by nsxmatt at 7:54 PM 9/29/2005
This one has a fresh motor, larger IC, a clutch that won't slip, and in a cleaner car to start with. Other than that it's about the same. Depending on the turbo I expect it to make more power just not sure how much. The car weighs more so I think it should run the same times, or hope at least, until I can build the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">Great lookin car man!
I think I smell 11.5s...
BTW, who made your mani? </TD></TR></TABLE>
11.5's I wish! Who knows, maybe
The manifold is Neukin. Alex is helping me out again
Lookin' good Matt. I knew you couldn't stay NA for long. I just sold my hatch this weekend as well and found a Captive blue shell in MD to pick up. It will be done correct w/ goals of 500whp. Good luck w/ the build. Later.
Phil
Phil
With all that shiny new name brand stuff you got there, might I suggest at least a $50 ebay radiator upgrade.
I don't mean anything negative, you may very well have a bigger radiator in your plans, but it seems like the tiny stock radiator you got there. After turbocharging my d15b vtec with a stock 92 cx radiator, the temp gauge would go up like a thermometer in hot water when I did wot pulls. Changed it for a plastic / aluminum 1" core off of ebay for $58 shipped and the gauge has stayed under the 1/2 way mark so far.
By the way nice car nice setup good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastbay92cx »</TD></TR><TR><TD CLASS="quote">With all that shiny new name brand stuff you got there, might I suggest at least a $50 ebay radiator upgrade.
A $50 ebay radiator uses the same core as a autozone dual core, which is nothing special. I ran my old setup on a stock but in good condition VX radiator with many back to back 11 second passes. No reason to upgrade unless it needs to be
looks killer, ill be damned if our cars dont look just alike, i mean way too similar
its hard to tell, but yeah those are slipstreams in the last pic, it was NA then and an auto-X car back in the day!
good color!
and i have been making pretty big HP numbers on a stock radiator, so dont buy some 50 dollar ebay radiator, as if you didnt know this already!
good color!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mochasi »</TD></TR><TR><TD CLASS="quote">who did or where did you get your IC pipping.. i need something just like that.. </TD></TR></TABLE>
It's Turbonetics piping I believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buda18 »</TD></TR><TR><TD CLASS="quote">wow, what size exhaust piping is that?
any plans to use a muffler?
It's 3 inch piping, no plans for a muffler at first. My old car ran open downpipe all the time, the noise didn't bother me just the fumes so this should make it a little quieter and less smelly
Can't wait to see the finished product.
