tach and rpm switch question
Old Sep 29, 2005 | 04:22 PM
vegaskurt's Avatar
Default tach and rpm switch question
Im about to wire in an rpm switch and wanted to get some opinions. Is it better to tap the signal wire off the distributer, ecu or cluster?
I'd rather tap into it under the hood so I dont have to mess with the wiring harness but I'm not sure wich wire. Any help would be great.
Old Sep 29, 2005 | 04:25 PM
Tyson's Avatar
Default Re: tach and rpm switch question (vegaskurt)
im just starting to get interested in an rpm switch, can you tell me which one youre going to buy?
anyone selling a used summit rpm switch?
Old Sep 29, 2005 | 04:32 PM
vegaskurt's Avatar
Default Re: tach and rpm switch question (Tyson)
I found an msd 8950 on ebay for $30 so I snagged it. The summit one is out of stock/backordered. Only downside of the msd is that you have to find a new pill to put in it to change the rpm engagement point.
They both ground a circuit out at a certain rpm so you need a relay to make the +12v connection to the solenoid. If I had the money I would go obd1.
Old Sep 29, 2005 | 04:34 PM
Tyson's Avatar
yeah, im just looking to make a shift light using stock dash indicators.
yeah, i noticed the summit one is backordered til 10/7.
im just waiting for a decent used deal anyway.
sorry for jacking the thread
Old Sep 29, 2005 | 07:56 PM
vegaskurt's Avatar
no prob, so does anyone know what wire on the cluster I have to tap into for the rpm switch?
BROKE.eg
Nov 20, 2005 02:03 PM
Tinker219
Sep 17, 2004 04:15 AM
Jeef
May 5, 2004 07:18 AM
stingray2772
Jan 6, 2003 10:23 AM
rioninja
Jun 21, 2001 11:22 PM
