How to make B18C5 rev Very High?
i was just wondering what has to be done to the motor to rev pass.. lets juss say.. around 9500 rpm - 10,000 rpm?
what kind of engine part has to be changed other than .. pistons, cams, retainers, valve springs.??
crankshaft?
crankshaft?
Balance crank wouldn't hurt. Having everything balanced and blueprinted will ensure the engine will last more than one race. Aftermarket valvetrain. Am I missing anything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">i was just wondering what has to be done to the motor to rev pass.. lets juss say.. around 9500 rpm - 10,000 rpm?</TD></TR></TABLE>
Just downshift from 4th to 2nd.
Works every time!
Works every time!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">
Works every time!
H'mm come to think of it I miught have some video of that ****.
Works every time!
</TD></TR></TABLE>H'mm come to think of it I miught have some video of that ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg »</TD></TR><TR><TD CLASS="quote">first it needs to make power there,
if it doesn't it's a moot point.</TD></TR></TABLE>
ditto
need good valvesprings
lightened rotating assembly & balance and blueprint = helps
.... just some random question that popped into my head: what are the main reasons connecting rods bend/break?
ditto
crankshaft should be fine, it can take a lot. You would probably have to bore it out and get new rods, manifold gasket and cams that produce power that high. And a very high CR, around 13-15CR. 3" header and exhaust. Balance and blueprint everything and some high octance gas. Talk to Tony the Tiger.
ok.. so i got
ctr pistons = CR 12.0 - 12.5 :1
RM M22xx cams, RM valve trains.(retainers, valve springs)
arp rod bolts.
stock crankshaft, rods.
so.. i need both crankshaft and rods to rev high safely?
arp rod bolts.
Works every time!
I knew someone would brign that one out sooner or later haha
Works every time!
</TD></TR></TABLE>I knew someone would brign that one out sooner or later haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">ok.. so i got
arp rod bolts.
Right on...let us know how it turns out
arp rod bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Tech Is Fading »</TD></TR><TR><TD CLASS="quote">
sure i will
</TD></TR></TABLE>sure i will
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Why do you want to rev that high?
You won't make power up there with M22's...</TD></TR></TABLE>
yeah.. actually my chip thing.. from RM is already set @ 9000 redline.
but i was just curious what kind of thing has to be done to achieve HIGH reving.
not that i'm actually gonna rev pass 10K+ .. but i wish i could
Hmmm... if I were building a B18C5 for the sole purpose of revving the **** out of it here's what I'd do:
86mm Sleeves
Knife-edged B16 crank
Custom reduced compression height pistons (maybe 12:1 CR)
Custom titanium rods to work with the short stroke and short pistons
Shitloads of headwork with high rate valvesprings and aluminum retainers
At least 52mm ITB's
Custom cams
Custom long tube header
and naturally have the thing balanced to all hell.
86mm Sleeves
At least 52mm ITB's
Custom cams
stock rods.
so.. i need both crankshaft and rods to rev high safely?</TD></TR></TABLE>
I don't think that list would cut it to make it a reliable 10k wonderspinner. I think a lot of people forget that as rpms rise, the stresses are exponential. I don't have the exact numbers, but to choose a piston like the CTR (heaviest Bseries VTEC slug) would not be wise if you want to spin it to "10k everyday" and expect "decent" longevity.
I would start at the rotating assembly - lightweight pistons, lightweight rods....stock crank is fine.... and perhaps another girdle....
stock rods.
I dont understand, what exactly do you want? Do you want to have a 9500 redline? Or do you just want to rev that high for fun? If you want to have your redline at 9500, your set up is NOT going to make it. But, if you want to rev up to 9500 it should be fine as long as you have aftermarket pistons, rods and valvesprings and dont drive it like you stole it.
And when I say your set up will not make it that high, I mean your not going to make power.
What I would do....
Sell the C5 block and buy a B18B block.
Have C5 crank knife-edged, tear dropped, and balanced by Castillo's.
Put C5 crank into B18B block.
Have some custom Cunningham titanium rods made.
86mm bore 11.5:1 CP Pistons
RLZ headwork
Crane roller rocker arms, custom cams
RMF or SMSP header
custom Jenvey ITB's
AEM EMS
Fuel cutoff 200 RPM above peak power
EDIT: To above post. Stock bottom end is good, but replace the rod bolts. M22's can make power that high, but not peak power.
RLZ headwork
RMF or SMSP header
custom Jenvey ITB's
AEM EMS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Sell the C5 block and buy a B18B block.</TD></TR></TABLE>
Somehow I fail to see the logic in this right here. You'd be sleeving anyway (86mm bore) and then having the LS block would just mean finding a crank girdle and running an external oil line.
Unless of course you sold the C5 block for a ton of money and picked up the LS for cheap.
Works every time!
Hell yeah... that was going to be my recommendation!
Works every time!
</TD></TR></TABLE>Hell yeah... that was going to be my recommendation!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat »</TD></TR><TR><TD CLASS="quote">Who's got that oooold video of SGT revving to 12k or so?</TD></TR></TABLE>
Not sure, but I ran across a night pic of him doing a clutch job in the Walmart parking lot during Expo 2. Hmmm.
Drinker
