d16y8 vs d16z6 head
Old Sep 29, 2005 | 02:29 PM
viskii420's Avatar
Default d16y8 vs d16z6 head
i been searching about this two cylinder heads .. to see wat is the difference between them.. im planin to go turbo but i dont know which of this head is more durable and powerfull.....i'm changing camshaft, springrs, valves 1mm over, ill do port and polish.. millings..but im still not sure which head is better than the other..do they have any differences?.... i seen pple swapin d16z6 head on d16y7 block.. also d16y8 head on d16z6 block... anyone can help me to chose between two of this.. or share any ideas which one is better..
thank you
d16z6 head
http://www.we-todd-did-racing....D.jpg
d16y8 head
http://www.angelfire.com/ultra/hondakidscarclub/
* i know its single cam and it slow.. if u dont know wat to post dont post..
* i know the blocks slightly different.... u need to have two set of head studs..
Modified by viskii420 at 4:14 PM 9/29/2005
Modified by viskii420 at 4:23 PM 9/29/2005
Modified by viskii420 at 4:25 PM 9/29/2005
Modified by viskii420 at 4:26 PM 9/29/2005
Old Sep 29, 2005 | 03:26 PM
viskii420's Avatar
bump
Old Sep 29, 2005 | 03:41 PM
EK k kay's Avatar
Default Re: d16y8 vs d16z6 head (viskii420)
Go with the Z6, less compression, but flows better than the Y8 does.
Old Sep 29, 2005 | 04:34 PM
viskii420's Avatar
last bump
Old Sep 29, 2005 | 05:35 PM
Civicse's Avatar
Default Re: (viskii420)
man search this, and like he said z6 flows better, which is better for turbo. but this has been talked about to death
Old Sep 29, 2005 | 09:41 PM
viskii420's Avatar
even w. the port, polish. chamber work, bigger valves....? z6 is more better?
Old Sep 29, 2005 | 10:57 PM
siregcivic's Avatar
i forgot what it was called someone explained it to me once... but the y8 head has different kind of ports.. where they are un equal... the ports are offset and flow less but the cumbustion chamber is smaller making it higher compression.... just go wtihh the z6 head
Old Sep 29, 2005 | 10:58 PM
92'si's Avatar
Woot Woot z6!!!
Old Oct 2, 2005 | 07:27 PM
viskii420's Avatar
i bought the crower stage 2 camshaft.. retrainers and springs for y8... would they work on z6?
Old Oct 2, 2005 | 07:33 PM
mike93eh
Guest
Posts: n/a
go with the z6. the combustion chamber volume is larger on the z6 so therefore it will give you a lower compression ration than a y8 head. lower compression is what you want with a turbo. it also flows better. the good thing about the y8 though is that it has some that helps prevent detenation, forget exactly what..
Old Oct 2, 2005 | 07:59 PM
viskii420's Avatar
even if i do chamber work... meanin from the square make into circle to fit the piston..
bc im lookin to run 78mm low compresion pistons.. still z6 is better?
Old Oct 2, 2005 | 08:18 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viskii420 &raquo;</TD></TR><TR><TD CLASS="quote">even if i do chamber work... meanin from the square make into circle to fit the piston..
bc im lookin to run 78mm low compresion pistons.. still z6 is better?</TD></TR></TABLE>
yea its still better, but if youre going to be doing some porting on the y8, go ahead and use it, itll be alright.
EKmitchSI
Feb 16, 2015 04:35 AM
DopeEJ1-510
35
Feb 5, 2008 12:43 AM
inane
Nov 10, 2004 07:59 PM
