Anyone ever had a Rotary Type (99-00 D16y7, 3 wire) IACV go bad on them?
EDIT:I NEED one of these ASAP! Either just the sensor itself or I'll buy the whole D16y7 TB. LMK. Thanks.
I have a 99' Sedan w/ the stock D16y7 in it. It has a y8 mani w/ the linear type IACV port blocked off so, that (like it came from the factory) it may utilize the 3 wire Rotary type IACV. The ECU is throwing a p0505 code (IAC malfunction) and it has a surging idle causing it to fail inspection. I've checked thew wiring, cleaned the valve as good as I can and even checked the ECU plug to make sure someone didn't attempt the 2 wire swap unsucessfully. If anyone has had one of these fail please let me know as I am stumped. Thanks
Phil
Modified by hondaguyef at 9:03 AM 10/2/2005
Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Seen a few of em.</TD></TR></TABLE>
Go bad?
Go bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">yes they go bad...
luckily i had an extra...
in fact i think i have one if you're interested</TD></TR></TABLE>
PM sent. Haven't we done Business before?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">PM sent. Haven't we done Business before?</TD></TR></TABLE>
i think we did... or at least i was trying to buy something from you...
i think we did... or at least i was trying to buy something from you...</TD></TR></TABLE>
Somethin' like that. Another PM sent your way BTW.
Phil
Phil
hondaguyef
Oct 2, 2005 05:02 AM
