power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 29, 2005 | 12:37 PM
projektvtec's Avatar
Default power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!!
my power locks arent working for some reason. i do have a jdm power window switch in the car so i had to rewire a lil so the master switch would work but im not sure if that would effect the power locks. the car is a civic 4dr 94. thanx
Old Sep 29, 2005 | 03:20 PM
hatchi's Avatar
Default Re: power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!! (projektvtec)
check your fuses. do you have instructions on how you rewired it to usdm spec?
Old Sep 29, 2005 | 04:54 PM
Default Re: power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!! (hatchi)
i figured out my own wiring but does the power windows effect the power locks??
Old Sep 29, 2005 | 05:43 PM
Philip's Avatar
electrical stuff is tricky. your problem is 90% you messin with the power windows. I say take it apart and study what all you did, compare it to a factory schematic (haynes or helms) but first check your fuses
Old Sep 30, 2005 | 08:21 AM
Default Re: power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!! (Philip)
is anyone positive that the power windows effect the power locks?? i have a wiring diagram of both and none of the wires interfere with eachother....and i checked the underdash fuse...are there any other fuses i shuld be aware of??
Old Sep 30, 2005 | 08:38 AM
i checked all fuses unserdash and under hood and they are all fine
Old Sep 30, 2005 | 10:56 AM
shepworldwide's Avatar
if you did the wiring i would check that.. even if you did solder you could have made a cold joint.
90% of all my customers would tell me their computer just stopped working i tell them to just plug it in and 85% of the time i'm right.
humans ??
Old Sep 30, 2005 | 11:29 AM
Default Re: power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!! (shepworldwide)
<U>YO THE POWER WINDOWS DONT EFFECT THE POWER LOCKS</U>
Old Sep 30, 2005 | 11:41 AM
could the power lock control unit be messed up internally for some reason????
Old Sep 30, 2005 | 12:19 PM
Echo7847's Avatar
Check input from the power door lock control unit. Behind door panel above speaker (ds door).
Disconnect connector: Use a dvom or dmm.
-Check the black wire for continuity with ground. (uses g552).
- connect yel/red to wht/grn terminal, and wht/red to blk momentarily. All doors should lock.
- connect wht/red to wht/grn, and yel/red to blk momentarily. all doors should lock.
Reconnect connector:
-check voltage @ wht/grn (should be 12v)
-move drivers power door lock switch to lock and check for voltage @ grn/wht (should be 1v or less)
-move drivers door lock switch to unlock and check voltage @ grn/red (1v or less)
- drivers door lock **** to lock position and check voltage @ blu/wht (1v or less)
Check back and let me know.
Old Sep 30, 2005 | 04:44 PM
Default Re: power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!! (Echo7847)
thanx ill try that tmrw
Old Oct 1, 2005 | 11:56 AM
didnt work
Old Oct 1, 2005 | 12:28 PM
i figured out the problem..thanx for your responses
Beegee208080
Jun 11, 2012 08:09 AM
projektvtec
Sep 29, 2005 05:13 PM
95excoupe
Mar 9, 2003 12:04 AM
fOmaNPu
Audio / Security / Video
Apr 20, 2002 11:09 AM
