How To CHange The Clutch?
I have a 93-1.5L. I plan to change the clutch soon, but do not intend to take it to the shop. I wanted to kow the procedures of dissassembling the transmission from the engine. Or Would I have to remove the three motor mounts, then remove the engine from the engine bay and disconnect the transmission from there. HELP
- Drain the tranny
- Disconnect all wires
- Support engine with a jack
- Unbolt engine mount and tranny bolts
- Remove tranny from car
- Remove the pressure plate
- Remove flywheel and have it resurfaced
- Reinstal flywheel
- Install new clutch disk, pressure plate, throw out bearing, pilot bearing
- Lift tranny back up and install back onto the engine
- Torque all bolts down
- Replace all wiring
- Fill tranny with fluid
Easy as pie!!
- Reinstal flywheel
Easy as pie!!
