HELP.. got an h22 with a Euro R manifold Leaking..
I have an H22 with the euro r manifold.. its leaking air into the bottom of the injectors (from injectors to intake manifold) ... wat o rings or seals should i use to stop the leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls-Turbo »</TD></TR><TR><TD CLASS="quote">so u dont need to rings then just use the sealer</TD></TR></TABLE>
You don't need anything other than the stock injector gaskets/rubber. If you are still leaking though, you can use some of the rtv. Or replace them, the choice is yours.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls-Turbo »</TD></TR><TR><TD CLASS="quote">wat 4 hole i have a vacum leak from the injectors</TD></TR></TABLE>
There is one hole per runner. It goes from the flange to the injector boss. It is before the injector seal. If you do not plug them, you will have a vacuum leak.
