Important: which program to tune OBD0 with ITBs setup?? HELP PLS
I have a fully built DOHC ZC engine with individual throttle bodies and OBD0 ECU. This way the ECU has to be tuned with TPS and not MAP sensor. My tuner said that in TurboEdit he could only tune it with MAP sensor - vacuum. Has anyone OBD0 ecu and individual thorttle bodies on his car? With which program can OBD0 ecu be tuned with TPS? Is there the only way to convert it to OBD1 ecu?
HELP ME, I HAVE A RACE ON SUNDAY!
You have a race in three days and you haven't even picked an engine management system, much less tuned the car??? I wouldn't hold my breath on making that race...
To answer your question, it's possible to tune the ITBs using the map sensor, but it won't give as smooth and friendly a tune as with Alpha-N blending like Crome can do. For a functional setup, use TurboEdit, but for a really easy to drive car, convert to OBD1 and use Crome.
Cloner
Nov 26, 2005 09:24 PM
