99 LS/VTEC TURBO AEM EMS
Old Sep 29, 2005 | 10:16 AM
diogo6's Avatar
Default 99 LS/VTEC TURBO AEM EMS in CA
Gonna have to let go of my baby immediately, but I have no idea what I could ask for it?
ENGINE UPGRADES
JE 9to1 Racing Pistons .5 Oversized (JE File Fit Rings)
Crower Billet Rods
Ferrea 1mm Oversized Intake Valves
Ferrea .5mm Oversized Exhaust Valves
CTR Intake Cam
ITR Exhaust Cam
Ferrea Dual Stainless Steel Valve Springs
Ferrea TI Retainers
Ferrea Stainless Steel Valve Keepers
Skunk2 B Series Adjustable Cam Gears
COMETIC 4 Layer Headgasket
ITR Oil Pump
ITR Waterpump
ARP Head Bolts
ARP Rod Bolts
ARP Crank Bolts
Darton Sport Sleeves
Honda Main/Rod Bearings
Aluminum Block Guard
Exedy Lightened Flywheel
Exedy Three-Puck Racing Clutch
MACHINE WORK
Hone Block to fit Sleeves/Pistons
Knife Edge Crank
Machine Head for Valves
Valvetrain Assembly/3 Angle Valve Job
Port Match Intake Manifold
Port Match Exhaust Manifold
Assemble Rods/Pistons
Balance Pistons
Balance Rods
Balance Crank
Deck Block
Line Hone Block
Micro Polish Crank
Assemble Pistons/Rods/Crank in Block
Balance Bottom End of Motor
Balance Bottom End with Exedy Flywheel
Balance Bottom End with Exedy 3 Puck Racing Clutch
Tap Out Head for VTEC Conversion
Modify Block for VTEC Gasket
TURBO SYSTEM
Greddy TD05-18G
Greddy Collector (Manifold)
Greddy Type S Blow-Off Valve
2 1/8" Charge Pipe to Intercooler
Greddy Type 31 Intercooler
2 1/2" Charge Pipe to Throttle Body
Blitz 720cc Low Imp. Injectors w/ Resistor Box
AEM Fuel Rail
AEM Fuel Pressure Regulator
2 1/2" and 2 3/4" Transition Downpipe
2 3/4" Test Pipe Section
Autometer Oil Pressure Meter (Electric)
Autometer Boost Gauge
Apexi AVC-R Boost Controller
AEM 3.5-BAR Map Sensor
ENGINE MANAGEMENT
AEM EMS Standalone Control Unit (30-1020)
AEM UEGO Wide-Band O2 Sensor
Motor Parts
B18A Block
B16A VTEC Head
LS Crank
ITR Manifold
I have some pics on http://99integra.shutterfly.com
It was street tuned by Sean from TorqueFreaks. This engine has less than 10000 miles on it. There's no cat, and with all the other mods, it won't pass smog in california, so that's why I'm selling it AS IS.
let me know what u guys think
Modified by diogo6 at 7:49 PM 9/29/2005
Old Sep 29, 2005 | 10:50 AM
diogo6's Avatar
Default Re: 99 LS/VTEC TURBO AEM EMS in CA (diogo6)
bump
Old Sep 29, 2005 | 06:05 PM
diogo6's Avatar
some input?
jdmept
Feb 25, 2013 07:15 AM
dc4teg95
Sep 26, 2008 11:51 AM
hondaracer93
Mar 13, 2006 09:13 AM
SrT4u2nV
17
Jan 4, 2006 08:09 AM
integRated109
May 8, 2002 09:49 PM
