Where to get metal gasket for Tial 38mm??
The damn gaskets that came with it keep blowing out...
I called Cometic, and they weren't quite sure what i was after.
Any help is much appriciated.
(i heard i can just run it without the gasket, but im unsure of this)
You need a gasket, trust me.
You can find them all over the place, google is your friend.
ATP has um.
The ones with the metal rings are way better.
ATP has um.
what you need isn teh deltagate fire ring gasket. Many people sell it on here just any turbonetics dealer should be abl to help you the tial paper is crap
I've read that if the surfaces are flat then you can use copper spray. Or if you use a WG gasket maybe a little copperspray on that will help? not sure if either of those are good ideas though.
Copper spray on the gasket will not help if you are burning them up.
Iv seen similar problem with some setups. You just need a gasket with the "fire ring" on it. Lots of company's make them not just turbonetics.
As I said, ATP has um.
http://www.turboneticsinc.com/pa_gaskets.htm
Part# 20142
Worked great for me running 20+ PSI of boost after I blew out a few other gaskets.
Part# 20142
The fire ring is between the WG and manifold, I dont remember if it came with one to go between the WG and dumpube. I need one though, the flange on my dumpube is warped so bad I can see straight through it in the middle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">You need a gasket, trust me.
ehh wrong answer try again. most people on here don't run a gasket including myself and i have never had a problem. hmm spend 20 plus shipping on a gasket or just save my money and run without.. i think the better option would be to run without.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">
Eh you try again, first off learn how to read. The gasket I posted is 5$
Second off running w/o a gasket or at least a layer of copper spray is a dumb idea IMO. I have tried it on 2 or 3 setups and it always leaks a little. Do what ever you want, im not to cheep for a 5$ gasket that is supposed to be there per all w/g instructions.
Id be willing to bet say 20$ that OVER 50% of the setups on H-T use the gasket.
You obviously only need it on the manifold side as its the only one seeing pressure.
And people are getting confused about the fire ring in the wg (IT MUST BE THERE OR THE WG WILL NOT HOLD BOOST) and the little metal ring around the gasket which turbonetics calls its "fire ring gasket".
</TD></TR></TABLE>Eh you try again, first off learn how to read. The gasket I posted is 5$
Or just shoot me your mailing address and I will mail you one in a regular envelope. The ones I have I make outta this grafoil (some chesterton material, I don't recall the exact pn) stuff I have at work. It's presssed carbon sheets with a stainless steel layer inside. I forget exacly the part number from mcmaster, but we use it at the power plant I work at for high pressure steam applications (I'm talking 1250-1500psi, 1000 deg F and ~300 klb/min flow), so it should work fine for a wg. It's great stuff.
Second off running w/o a gasket or at least a layer of copper spray is a dumb idea IMO. </TD></TR></TABLE>
hit the search button then type in "tial gasket", then click archeived and tell me what u see. i'll save u the time. you'll see post like this:
https://honda-tech.com/zerothread?id=1350577
if the manifold surface is flat there shouldnt be a leaking problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">yeah most people dont runt them
do you run a gasket inbetween you turbo and your downpipe? no
ok there your anwser</TD></TR></TABLE>
true^^^....im not running no gasket on my downpipe,manifold and wastegate for over 1yr now and no sign of leak thats on 14lb + daily...lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumpeDc2 »</TD></TR><TR><TD CLASS="quote">You neet the one that has the metal ring It will last for ever </TD></TR></TABLE> You have to have the fire ring between the WG and manifold or your boost level will be all messed up, and you will have boost spikes and sheeeeet
Ive been running with out one for a few months now with no problems, i had it on there at first and it blew out after 3 days.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">As I said, ATP has um.
these pictured have the "fire ring" ???
</TD></TR></TABLE>these pictured have the "fire ring" ???
