?!Gear/Brake Release Switch!?
Old Sep 29, 2005 | 07:02 AM
96max2fast's Avatar
Default ?!Gear/Brake Release Switch!?
Hi, i have a 2000 accord coupe V6 (automatic trans).. Sometimes when i press the brake i cannot take the car out of "Parking".. When i went under the dash board i noticed that the little push button on the brake pedal was not popping out when i press the brakes.. I have to play with that little switch so it can pop out. Can someone help me and tell me what this piece is called. Also, how can i fix this problem.. Is this piece expensive?
Thanks alot for the help !!
Old Sep 29, 2005 | 09:44 AM
JimBlake's Avatar
Default Re: ?!Gear/Brake Release Switch!? (96max2fast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96max2fast &raquo;</TD></TR><TR><TD CLASS="quote">... how can i fix this problem...</TD></TR></TABLE>Sometimes it's bracket gets bent or the wiring gets unplugged. But it sounds like you need a new brake light switch.
Old Sep 29, 2005 | 10:52 AM
96max2fast's Avatar
Default Re: ?!Gear/Brake Release Switch!? (JimBlake)
How much is that switch?? anyone know how to remove it?
Old Sep 29, 2005 | 11:26 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96max2fast &raquo;</TD></TR><TR><TD CLASS="quote">How much is that switch?? anyone know how to remove it?</TD></TR></TABLE>
You might want to make sure that's what it is first? Do the brake lights work when it's acting up?
Old Sep 29, 2005 | 12:00 PM
96max2fast's Avatar
Default Re: ?!Gear/Brake Release Switch!? (Chiovnidca)
i know its that piece because the actual push button does not pop out.. it gets stuck in there when i press the brake. i tried putting wd40 and it still gets stuck inside..
PREACHERBREW
Jun 5, 2008 03:47 PM
Jameson
Aug 3, 2007 04:00 PM
haz19
Oct 23, 2005 01:14 PM
Lacie in Distress
Aug 26, 2005 07:20 PM
Sarren
Jul 14, 2004 12:32 PM
