Clutch throw out bearing?
Old Sep 29, 2005 | 03:53 AM
aznrexboi00's Avatar
Default Clutch throw out bearing?
Hello, Im having a problem with my transmission...it's making really loud rattling noises...i changed the clutch and all the bearings the beginning of this yr...when i put even a little pressure on the clutch..the noise goes away....but i remember i had a hard time with the clip on the fork...the little thing that looks like a paper clip...i think its called a fork spring....well...would it make the noise if the clip would have fall out? or not in place? please let me know...thank you
Old Sep 29, 2005 | 05:29 AM
Default Re: Clutch throw out bearing? (aznrexboi00)
ttt
Old Sep 29, 2005 | 06:02 AM
mike1114's Avatar
throw out bearing is bad.
I have that same ****, been driving for 6 months still. I'm rocking it till it doesn't shift anymore. Its my beater car anyway.
Old Sep 29, 2005 | 06:52 AM
Default Re: Clutch throw out bearing? (mike1114)
lol, thanks but what make you so sure that my problem is the throw out bearing and not input shaft bearing?
Old Sep 29, 2005 | 07:42 AM
Sivik's Avatar
i have the same problem... but i haven't fixed mine either. its either the throw-out bearing or the input shaft bearing. my buddy who works at honda in the service dept says its the throwout bearing but i won't know until i take it off.
Old Sep 29, 2005 | 11:23 AM
Default Re: (Sivik)
so will the spring or clip that im talking about cause the throw out bearing not to engage? i think its called a fork spring or something...
Old Sep 29, 2005 | 11:42 AM
mike1114's Avatar
Default Re: (aznrexboi00)
input shaft bearing...sorry, my head said one thing and typed another.
https://honda-tech.com/zerothread?id=596873
Old Sep 29, 2005 | 01:23 PM
xhatchracerx's Avatar
Default Re: (mike1114)
before u go and change out your throw out bearing u might want to try and just lubricate the clutch release fork
Old Sep 29, 2005 | 06:29 PM
so would it be the isb or throw out bearing? anyone knows for sure?! thanks in advance
Old Sep 29, 2005 | 06:36 PM
.Ry's Avatar
.Ry
There is NO way to know untill you pull the tranny. Ive searched through the old threads and just by the sounds and actions alone noone could tell what was wrong with it untill they pulled the tranny.
Old Sep 29, 2005 | 06:45 PM
C2daIzZle's Avatar
okay, fellow honda-tech'r heres the thing it is definitly one of two things, a)throw-out bearing b) input shaft bearing. for your sake i hope its #b. however, pull your tranny & take a look see for yourself, have a helms handy i advise. i would make sure all of the bearings, springs, lubed accordingly before you replace anything imo. hope this helps, gl.
Old Sep 29, 2005 | 06:46 PM
tpr's Avatar
tpr
To fix whatever is wrong the transmission must come out. My money is on the input shaft bearing or the throwout bearing. The input shaft stops turning when you depress the cluth pedal, or at least it should. Also at the same time a load is being placed on the release bearing, loading the loose bearing makes it get quieter sometimes. Thats why as has already been stated. Pull that trans! And know the truth.
Old Sep 29, 2005 | 06:47 PM
wwang924's Avatar
Default Re: (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">There is NO way to know untill you pull the tranny. Ive searched through the old threads and just by the sounds and actions alone noone could tell what was wrong with it untill they pulled the tranny.</TD></TR></TABLE>
I can say thats pretty much true, i did the ISB and clutch replacement. total three bearings changed. Still has the noise that goes away when i step on the clutch. Its obvious its a bearing sound, my friend is a honda technician confirmed this. So i say next time when you pull the tranny off check ALLLL bearings. my ISB was perfectly fine btw.
Old Sep 29, 2005 | 07:03 PM
so where could i buy some bearings?
Old Sep 29, 2005 | 07:25 PM
.Ry's Avatar
.Ry
Honda! thats your best bet for the best fitment for a ISB. Now if you need a throwout or pilot bearing just buy a new clutch KIT, and it will come with them. The ISB is like $20-$30 bucks from honda. They use another name for it though I think.
Old Sep 30, 2005 | 08:42 AM
what is the input shaft bearing called in the helms?
Old Sep 30, 2005 | 09:58 AM
ttt
Old Sep 30, 2005 | 10:46 AM
shepworldwide's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">throw out bearing is bad.
I have that same ****, been driving for 6 months still. I'm rocking it till it doesn't shift anymore. Its my beater car anyway.</TD></TR></TABLE>
me to. i'm waiting till my guts blow out so i have an excuse for an ex trans
Old Sep 30, 2005 | 10:50 AM
.Ry's Avatar
.Ry
Default Re: Clutch throw out bearing? (shepworldwide)
How much do you plan on spending for an EX tranny?
Old Sep 30, 2005 | 10:52 AM
Default Re: Clutch throw out bearing? (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">How much do you plan on spending for an EX tranny?</TD></TR></TABLE>
why you have an offer?
i think it would be cheeper to get from my local junkyard. about the cost of you just to ship to me
Old Sep 30, 2005 | 12:53 PM
.Ry's Avatar
.Ry
lol no just becareful your not buying a high mileage tranny because it will be nothing but problems. I have some noise coming from my tranny not sure what it is but ive looked into these guys https://honda-tech.com/zero...85206. I just asked them how much for a D series Ex tranny, not crazy but not a great deal. If you search D series trannys have some issues 100,000 miles +.
Old Oct 1, 2005 | 09:02 AM
thank you guys....so once again can someone tell me what is the fork release spring used for?
civic ef
May 29, 2012 01:02 AM
KHaoTiK
12
Feb 23, 2010 02:29 PM
spens 91 Ef
29
Mar 8, 2009 08:15 AM
93 EG
12
Mar 3, 2007 08:14 AM
candy eg
Jan 12, 2006 08:48 PM
