Stock timing belt?
Old Sep 29, 2005 | 01:13 AM
ITSUKA's Avatar
Default what's the best option?
it's almost time for a new timing belt, so my question is...is a stock timing belt sufficent for a itr with i/h/e vafc2 tuning and a lighten flywheel?
would a toda timing belt be an over kill? is there pros and cons of this?
pleaes keep in mind that within the next 100,000kms i wold be up grading to toda b package.
or would it be better to get a stock timing belt for now, and get the timing belt when the time comes?
thx in advance!
Old Sep 29, 2005 | 06:22 AM
Chris F's Avatar
Default Re: what's the best option? (ITSUKA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSUKA &raquo;</TD></TR><TR><TD CLASS="quote">or would it be better to get a stock timing belt for now, and get the timing belt when the time comes?</TD></TR></TABLE>
Stock timing belts are great, especially for stock valvetrain.
Old Sep 29, 2005 | 08:19 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: what's the best option? (Chris F)
Stock belt. No need to go to TODA
Old Sep 29, 2005 | 12:14 PM
cmdr430's Avatar
stock belt is fine.... even when you go to B's.....
...... as long as it is tensioned correctly......
Old Sep 29, 2005 | 05:30 PM
uNF$@#!'s Avatar
Default Re: what's the best option? (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
...... as long as it is tensioned correctly...... </TD></TR></TABLE>
and lots of people would disagree...including myself.
Old Oct 1, 2005 | 02:46 AM
ITSUKA's Avatar
Default Re: what's the best option? (255.255.255.255)
thx for the replies guys although i have mixed feelings about it!
i think stock timing belt is fine until i go toda b
one last question, if my stock injectors needs replacing would be a good idea to get a larger cc? i.e. 290cc
i then would have to retune again won't i?
thx again
Old Oct 1, 2005 | 08:55 PM
Haleiwa-Brando's Avatar
Before you go to the stealership, I have a used one with 5k miles on it. Mint condition, no frays, cracks or miscoloring. Stored properly. If you want it send me an IM.
Old Oct 1, 2005 | 09:08 PM
b19coupe's Avatar
Stock belt is fine with Skunk Stage 2's, Pro 2's, and Toda 'C's. This from personal experience. Proper tension is the key
Old Oct 2, 2005 | 05:01 PM
Black R's Avatar
25 Year Member
.....just get brando's belt.
The injector issue: get 290cc (98+ prelude injectors) or 310cc saturated injectors... These are the biggest the obd2 ecu can accommodate.
You can actually go with 450cc or so if you like - even 550cc would be good as theft prevention should you remove your ecu... and saturated seem to be able to idle a bit better... But you'll need a programmable ecu for this (obd1).
-hth
imadigitalgod
Aug 18, 2023 08:01 PM
bet_88
Sep 7, 2006 02:49 PM
pornstar4777
May 23, 2006 05:43 PM
realis9
Jul 19, 2005 07:47 AM
NA gs-R 05 C
Apr 29, 2003 07:44 AM
