12:1 comp but what cams???
Old Sep 28, 2005 | 06:44 PM
neophyte210's Avatar
Default 12:1 comp but what cams???
i bought a newly rebuild b16a with 12:1 comp pistons .... aventually i would like to make around 190 -200whp ... what kind of cams should i go with .. i was lookin towards jun3 ... hit me up .. i have stock poop header tight now with kteller pipeing and ghetto intake
Old Sep 28, 2005 | 08:28 PM
Junkyard2000's Avatar
Default Re: 12:1 comp but what cams??? (neophyte210)
skunk2 stage2
Old Sep 28, 2005 | 09:24 PM
boosted k20's Avatar
Default Re: 12:1 comp but what cams??? (Junkyard2000)
SKUNK2 PRO1's
Old Sep 28, 2005 | 09:48 PM
2k.civic.si's Avatar
Default Re: 12:1 comp but what cams??? (boosted k20)
skunk2 stg2...jun3's...toda b's...m22...b16's like to rev high to make power....give them a cam that can breath that high....
Old Sep 29, 2005 | 08:52 AM
Default Re: 12:1 comp but what cams??? (2k.civic.si)
whats a better cam for my setup skunk2 stage2s or like some jun3's ..... ive heard amazing things about jun cams....
also i have some cams that have surface rust on them how do i fix?
Old Sep 29, 2005 | 08:55 AM
also what cams are more streetable??? what kind of gains can i expect from them??
Old Sep 29, 2005 | 10:38 AM
Used2beAb16's Avatar
For a super high rpm b16 I would like a jun III's since streetability is a real concern. The jun III's are a peaky top-end cam with a stock like profiles off of vtec. You will retain stock idle, and driveability. (which makes it nice for tuning aswell.) But up top where the b16's make power, the juns aggressive ramp angles will make gooo good power.
Also note that skunk 2 stage 2 is very similar. (i like juns though!)
Old Sep 29, 2005 | 10:47 AM
joelsgirlisfatandugly's Avatar
Default Re: 12:1 comp but what cams??? (Used2beAb16)
go big or go home!
Old Sep 29, 2005 | 10:54 AM
accorse07's Avatar
Default Re: 12:1 comp but what cams??? (joelsgirlisfatandugly)
junIII's the way to go...
Old Sep 29, 2005 | 10:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joelsgirlisfatandugly &raquo;</TD></TR><TR><TD CLASS="quote">go big or go home! </TD></TR></TABLE>
get out or shut up....
personally between the skunk2 stg2's and the jun3's for the money i would go with the skunk cams...
Old Sep 29, 2005 | 11:06 AM
I go jun III's because they are came up with grind first and its still killer to this day.
Old Sep 29, 2005 | 11:13 AM
clayton bigsby's Avatar
TODA B's or C's
Old Sep 29, 2005 | 11:37 AM
UncleD's Avatar
Default Re: 12:1 comp but what cams??? (clayton bigsby)
Jun 3/M22x work very well with that motor
Old Sep 29, 2005 | 11:49 AM
TrackSpeedRacing's Avatar
Default Re: 12:1 comp but what cams??? (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Jun 3/M22x work very well with that motor </TD></TR></TABLE>
I agree
Old Sep 29, 2005 | 12:39 PM
Default Re: 12:1 comp but what cams??? (TrackSpeedRacing)
i can get jun3's for 500 shipped with valvetrain .. and some minor surface rust or i can get some skunk2 stage2's for 200 but just the cams .... does the head have to come off to put new valvetrain in??
Old Sep 29, 2005 | 01:52 PM
95BG33PGSR's Avatar
I've had both cams, and I like the skunks a lot more. and about your last question about taking the the head off, to do the valve train, If you plan on just replacing cams and springs/retainers, you can keep the head on, but if you wish to the replace valves, you have to remove the head, if you decide to replace valves, i'd highly suggest valves that are coated w/ black nitrade...it has more resistance to heat and friction. mine are made by super-tech and i love them. Good luck w/ the build
Old Sep 29, 2005 | 05:47 PM
Default Re: (95BG33PGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95BG33PGSR &raquo;</TD></TR><TR><TD CLASS="quote">I've had both cams, and I like the skunks a lot more. and about your last question about taking the the head off, to do the valve train, If you plan on just replacing cams and springs/retainers, you can keep the head on, but if you wish to the replace valves, you have to remove the head, if you decide to replace valves, i'd highly suggest valves that are coated w/ black nitrade...it has more resistance to heat and friction. mine are made by super-tech and i love them. Good luck w/ the build</TD></TR></TABLE>
reason u like the skunks better because besides price i dont know of one?
Old Sep 29, 2005 | 06:50 PM
Default Re: (Used2beAb16)
im running skunks also
Old Sep 29, 2005 | 09:15 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Re: (Junkyard2000)
I'd look at Skunk Stage 2's, Buddy Clud Stage 3's or Crower 404's.
Old Sep 29, 2005 | 09:34 PM
Humble Performance's Avatar
Default Re: (Blazin Si)
I personally like the M22x , very good cams !
Old Sep 30, 2005 | 04:59 AM
Phatch99's Avatar
Default Re: (8secEg)
skunk 2 stg 2 require valvetrain? i heard u can run them on stock valvetrain but can only rev to 8k?
Old Sep 30, 2005 | 05:17 AM
jdmcx's Avatar
Default Re: (Phatch99)
crower 63413
jason
Old Sep 30, 2005 | 07:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 &raquo;</TD></TR><TR><TD CLASS="quote">skunk 2 stg 2 require valvetrain? i heard u can run them on stock valvetrain but can only rev to 8k? </TD></TR></TABLE>
yes, the stage 2 are aggressive cams. Stage 1's are fine with stock valvetrain
Old Sep 30, 2005 | 09:20 AM
Phatch99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 &raquo;</TD></TR><TR><TD CLASS="quote">
yes, the stage 2 are aggressive cams. Stage 1's are fine with stock valvetrain</TD></TR></TABLE>
n e body on h-t here run stage 2 or higher cams on stock valvetrain?
Old Sep 30, 2005 | 09:44 AM
jdmcx's Avatar
i don't think it would be a good idea to run bigger cams without upgrading the valvetrain.
my guess is you could probably do it but not for long also when upgrading cams i personaly like to pull the head change seals springs ect.. you can never tell what you can find and prevent from happening, any way it is also a good idea to clay your motor when going with big cams
just my .02
jason
