VAFC2 blowing fuse.......
installed a VAFC2 and it keeps blowing my alt./speed sensor fuse. this is getting really annoying, any suggestions? i already pulled it out and completly re-wired it today and the same thing happened again. TIA
Did you rewire to stock or rewired the VAFC back in? See if this happens with everything back to stock. If it does then you have another problem. If not then something with the VAFC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Did you rewire to stock or rewired the VAFC back in? See if this happens with everything back to stock. If it does then you have another problem. If not then something with the VAFC. </TD></TR></TABLE>
sorry i didnt specify, i took out the vafc and everything was fine, i rewired the VAFC back in in new locations farther away from the ECu and it is happening again. VAFC is bad msybe?
Oh ok, i didnt get that you put it back to stock. Most people just take it off and rewire without trying it stock. Could be that you got a bad VAFC. Did you put the correct ground and power in the right spots? One goes before the other and have to be atleast an inch appart. That would be the only thing i could think of other then defective VAFC.
allmotorsi04
Jul 11, 2004 03:08 AM
EK_BackHatch
12
Mar 4, 2004 02:05 AM
