washer trick question
Old Sep 28, 2005 | 04:26 PM
asianalbutt's Avatar
Default washer trick question
ok i seen the washer trick to get rid of the camber in the back. i was wondering how many washers i need for a 1.75-2in drop in the back???
Old Sep 28, 2005 | 04:41 PM
xbn83's Avatar
Default Re: washer trick question (asianalbutt)
Buy a protractor or a leveler and see it for yourself. No one would know how many washer you need. Each washer has different thickness.
Old Sep 28, 2005 | 05:50 PM
jb.'s Avatar
jb.
Default Re: washer trick question (xbn83)
yeah, you just have to try b/c every car is different
Old Sep 29, 2005 | 05:09 AM
m0t0rhead's Avatar
Approximately 3-4 washers per bolt x 2 bolts - so 6-8 on each side.
Of course this depends on the thickness of each washer.
Old Sep 29, 2005 | 08:08 AM
hmm well if i use the DIY that jbkiksass69 did and i use those kind of washers he used then how many do you think i would need?
Old Sep 29, 2005 | 04:06 PM
anyone?
Old Sep 29, 2005 | 04:48 PM
jb.'s Avatar
jb.
Default Re: (asianalbutt)
what worries you so much. i had to buy the washers in a bulk pack, and its not hard to take the wheel off to add some. i would wait until your springs settle first b/c people have more weight in the back/front of their car. for instance, i had a fairly low drop on my coilovers, and i have a heavy speaker system in the back, so it would be lower. you just have to figure it out for your car. from the alignment specs, its about .25 degree per washer if i remember
600_Double_R
Oct 29, 2006 07:06 AM
chestnut_55
Dec 28, 2005 11:26 PM
lil k
May 19, 2003 12:22 AM
fastgreenmachine
Feb 12, 2003 11:26 AM
