Clearance with stock fan and RMF Narrow header
Old Sep 28, 2005 | 04:11 PM
JDM Factor's Avatar
Default Clearance with stock fan and RMF Narrow header
Just got the RMF Narrow style header and had a question with fitment issues. I wanted to know if anyone had problems. I have the stock fans in the car right now. It doesn't look like there will be a problem with the A/C fan but the radiator fan is the question. I don't think I'll have problems with the header actually touching the fan, but the shroud looks like it will be in the way. If anyone has any info please post it up Also, it is a ceramic header but if the header fits, im just worried about the fan/shroud melting now....
Old Sep 28, 2005 | 06:21 PM
JDM Factor's Avatar
Anyone?
Old Sep 28, 2005 | 06:34 PM
IN VTEC's Avatar
Default Re: Clearance with stock fan and RMF Narrow header (JDM Factor)
Trim it. As long as the #4 primary doesn't get into the fan blades' path, it'll be just fine.
Old Sep 28, 2005 | 08:00 PM
Lifter2012's Avatar
Default Re: Clearance with stock fan and RMF Narrow header (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Trim it. As long as the #4 primary doesn't get into the fan blades' path, it'll be just fine.</TD></TR></TABLE>
yea what he said ^ hahaha
Old Sep 28, 2005 | 08:02 PM
JDM Factor's Avatar
Im just worried about the shroud/fan melting now...
Old Sep 29, 2005 | 05:46 AM
jeremy.'s Avatar
Default Re: (JDM Factor)
i was told you would need a slim fan....they don't cost that much anyways
Old Sep 29, 2005 | 05:56 AM
Slick GS-R's Avatar
Default Re: (ekay_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">i was told you would need a slim fan....they don't cost that much anyways</TD></TR></TABLE>
Yea, go to Autozone and get a slimline for ~$40
Old Sep 29, 2005 | 06:00 AM
citrus3000psi's Avatar
Default Re: (Slick GS-R)
Be carefull with those autozone fans. I bought one and it stopped working after about 4 to 5 months. Car started getting hot at idle.
But I don't think it will melt the shroad. And you said the header was ceramic so thats even better for controlling heat.
Old Sep 29, 2005 | 06:11 AM
IN VTEC's Avatar
If you need to, you can wrap the section of header that's closest to the fan. That's what I did on my header. But, even without it, I never had any problems with the fan being too close to the heat. I was more concerned about the clutch slave cylinder.
Old Sep 29, 2005 | 06:24 AM
victorpapa's Avatar
Default Re: (citrus3000psi)
JDM I installed the rmf narrow on my itr 4 days ago.
Excuse me for my bad english but i'll try to help you.
You will not have any problem whit the stock fan, you have only to leave it in order to install the header. I removed some plastic from the fan chassis in order to avoid the header scratch.
The hader will only melt a little bit the fan chassis but not the blades. After the melting pay attention to the melted plastic and remove it with a cutter. Check the moving/path of the blades , on my esperience the melted plastic stopped the fan ( but it is easy to remove).
Old Sep 29, 2005 | 07:14 AM
JDM Factor's Avatar
im not even gonna hassle with melting issues, I just ordered a slimline fan, thanks for the help guys.
Dave_Matthews
29
Jul 15, 2011 03:51 PM
mullet eater
May 10, 2008 02:58 PM
LoneStarCRX
Sep 22, 2004 05:22 PM
mr_mbuna
Aug 3, 2003 09:19 PM
typeRicer hater
Jan 21, 2003 07:17 PM
