clicking noise
Old Sep 28, 2005 | 03:48 PM
village_idiot's Avatar
Default clicking noise
get this noise when turning. its a very rapid clickclickclickclickclick. steering wheel must be pretty much locked in either direction for the noise to occur. it doesnt sound like an axle to me. could be though but it does it both directions. what else could cause a noise like this when turning?
Old Sep 28, 2005 | 03:51 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: clicking noise (village_idiot)
Does the noise increase as your wheels turn faster? Or are they proportional to engine speed?
Could it be the wheels hitting something in the well? Does it sound more like a clicking or a knocking? (Knocking meaning it has more of a bassy/deeper sound than a clicking)
Old Sep 28, 2005 | 03:56 PM
h4x's Avatar
h4x
CV joints
Old Sep 28, 2005 | 03:59 PM
91DApwr's Avatar
Default Re: (h4x)
yeah cv joints may be leaking heave it checked out if you look underneath check and see for a leaking smelly type of oil thats from the joint
Old Sep 28, 2005 | 04:12 PM
its more of a click shamoo. its been a while since ive had a gay axle but as i recal it was a knock and it wasnt so rapid. any ideas? has nothing to do w/ rpm nor how fast the wheel is turned. it pretty much has to be locked to the right or left.
Old Sep 28, 2005 | 04:52 PM
Muckman's Avatar
Moderator in Chief
Default Re: (village_idiot)
CV Joint. At full lock the CV joints are under the most stress.
Old Sep 28, 2005 | 05:41 PM
ok so your saying my cv's are bad on both sides and i should ignore the fact that it sounds completely differenct from my experiance w/ bad cv's. obviously i will check them out but can anybody think of anything other than cv's?
Old Sep 28, 2005 | 05:47 PM
Muckman's Avatar
Moderator in Chief
Obviously I cannot hear the noise so Im going on your description. By your description it sounds like bad axles. Things can wear and break differently causing a slightly different sound.
Another thing to look at would be the wheel bearing. Jack up the front and see if you can wobble the front wheels horizontally and vertically.
Old Sep 28, 2005 | 05:52 PM
kchungb17a's Avatar
Default Re: (Muckman)
Bad CV joints typically come from lots of miles with a blown CV boot(s). That's a reasonably easy check. Have you looked?
Old Sep 29, 2005 | 05:31 AM
i have not looked but i will. is there anything else that could cause this?
Old Sep 29, 2005 | 05:34 AM
Backk InTheDA's Avatar
I hate everything
Default Re: (h4x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h4x &raquo;</TD></TR><TR><TD CLASS="quote">CV joints</TD></TR></TABLE>
Good way to test this, is throw your car into reverse, and then crank the wheel all the way to one side, and back up at about 10-15mph, if you hear that noise, your joints are wearing and more than likely need to be replaced.
picthis1
Dec 17, 2017 07:54 PM
mrc3
Honda Accord (2013 - 2015)
Nov 30, 2017 04:33 AM
THE GAME IS THICK
12
Jun 29, 2003 12:15 PM
td04civic
Feb 6, 2002 05:44 AM
