ECU H23 Question, about P72
Old Sep 28, 2005 | 02:01 PM
WiteSiprelude's Avatar
Default ECU H23 Question, about P72
ok so i read the post....https://honda-tech.com/zerothread?id=567799..... And i Had the question about the P72.... Firedrake said that the P74/75 are the best pick for the H23 but what is i don't want to lose the IAB's. or dose it matter if i plan to boost the motor.. So what i'm asking is...will the p72 still work with the H23, ahter i install Hondata or uberdata....? which would be best......
Old Sep 28, 2005 | 07:00 PM
prospeed's Avatar
Default Re: ECU H23 Question, about P72 (WiteSiprelude)
Yes the p72 will work. You will only be using the lower maps because you don't have vtec. Personally the LS ecu will work just fine but if you really want butterfly action the the p72 is really the only way to go.
xxmastermindxx
Nov 22, 2007 05:27 PM
ed_1
Sep 22, 2005 03:59 PM
SlammedCD7
Aug 11, 2004 06:18 PM
prjct92eh2
Mar 23, 2004 09:04 AM
