New Radiator
Hey fellas,
Has anybody bottomed out their car that hard, that it cracked the radiator on the bottom. I need to replace mine and i am just having a hard time imagining the car would bottom out THAT LOW.
Just wondering though.
Lata
Lata
Is that why you're replacing your radiator, because you bottomed out? DAMN!
If that's so, I'd be worried more about other engine components than an easy/cheap to replace radiator. Wouldn't the oil pan hit WAY before the radiator?
EDIT: I just re-read your post. So you didn't actually bottom out that low, you're just asking if it's possible. I guess it would be possible, but there would be a lot of other damages if that happened. I would venture to guess that your bottom endtank cracking isn't caused by a bottom-out. Honda radiators generally fail at the endtanks because they are plastic. It's pretty common. When replacing it, try to get one with meta endtanks.
