A few ?'s concerning LSVTEC
Old Sep 28, 2005 | 11:15 AM
SKDRCR's Avatar
Default A few ?'s concerning LSVTEC
My friend has a 98 Integra LS with the B18c1 head on it.
He has a few problems with it though.
First of all, he's throwing 3 CEL's on it.
Code 20-Electrical Load Detector
Code 23-Knock sensor
Code 45-Fuel system too lean
Here's my questions.
1.Are these normal codes that you guys run into with the LSVTEC setup?
2.Will any of these codes cause Vtec to not engage?
3.Is it possibile that he's not getting enough oil pressure to the head?
4.Should he be running the b18c1 oil pump on this setup.
Is it the same as the ls oil pump?
He's getting a loud ticking sound if he's over 6k rpms.
He's already done a valve adjustment on it as well.
Any input you guys have on this would be greatly appreciated.
thx, Chris
Old Sep 28, 2005 | 11:19 AM
Kendall's Avatar
Use an ECU that doesn't have knock sensor capabilities as the LS block doesn't have a knock sensor. In fact get a chipped P28 and it should take care of codes 23 and 45 (assuming you get a suitable program). You may have to bust out the manual and a multimeter to get rid of the code 20.
Old Sep 28, 2005 | 12:31 PM
hondaluva's Avatar
Default Re: (Kendall)
C-speedracing.com has a pretty simple fix for that knock sensor problem. If you don't want to eliminate knock or you can just run hondata and eliminate knock.
cadwiese
12
Dec 6, 2008 02:00 PM
Jonzo
Jun 25, 2005 11:28 AM
matman4444
Jul 30, 2004 09:30 AM
Defi4nce
Apr 25, 2004 10:01 AM
CRXSIFUEL
Jan 12, 2003 05:13 PM
