So you want a HID retrofit for your EG? I do them. click here for details
https://honda-tech.com/zerothread?id=1431506
New Thread Made.. More pix and Customer pictures as well
Modified by JDMlyfestyle at 8:12 PM 11/11/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_SpeC_EK »</TD></TR><TR><TD CLASS="quote">i take it you wont do accord headlights??</TD></TR></TABLE>
PM'd
PM'd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon_Fed_EM1 »</TD></TR><TR><TD CLASS="quote">how about ek head lamps?</TD></TR></TABLE>
Ill PM you and ill do some more Research on them and look how its done
Im pretty confident that i can do this with EK housings. But just note that the EK's backside will not look stock cause i will have to cut it in the back to fit the projectors.
The labor will be a little more like 40-50 more since i will have to do more work and use more products to ensure a good sealed design. but yes i can do EK's
nice, seems like a reasonable price! I may be in the market in the next month or two.
My car has been down for a while, but when it was running I remember the projectors I have (denji) being tough to aim.
IF you get a set of headlamps that might not have been aimed well, could you remedy that during the HID install?
yes i can fix the aiming of the headlights when i do a retrofit. If i do a set of EG headlights i set them on my car and aim them to how i would have my HID's Aimed but if you wish to change that when you recieve them then you may.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">wow all these peeps want retrofits done but no one really wants to step up to the plate</TD></TR></TABLE>
Another dumb question-
Does this setup utilize the car's stock wiring? If not, do you show instructions on how to wire them up?
Thanks again! How can I get more of a refined price range for what I want?
edit - i realize some wiring wil appear if you use the bi-xenon but what about the other, non high beam setups?
Yes your stock harness may need to be modified since i do include a HID wiring harness with all my retrofits for an Extra $25.
This allows you to save your stock wiring cause it simply cannot handle the 30 amp draw from the ballast. the HID's will surely destroy your stock wiring and fry it.
