Need new passenger mount in Eg. How do I install?
Old Sep 28, 2005 | 09:56 AM
Project92Hatch's Avatar
Default Need new passenger mount in Eg. How do I install?
Well Ive searched on auto to manual conversions but I have a hatch that had a h22 and then they modified the stock mount for the h22. I have a new stock mount that i want to put it in. It looks like the mount is spot welded. Do I just drill the mount out and weld in the stock one? But the holes ur supposed to weld the mount in at, Arent those holes already drilled out on the frame. If anybody has instructions on this that would be much help. I need this done asap. Thanks
Old Sep 28, 2005 | 10:51 AM
dognutz's Avatar
Default Re: Need new passenger mount in Eg. How do I install? (Project92Hatch)
It would be helpful if you could post pic's of the problem area and new mount
Old Sep 28, 2005 | 01:29 PM
Default Re: Need new passenger mount in Eg. How do I install? (dognutz)
Well all it is, is the passenger top mount and they cut one of the edges off the side of the stock mount. So they could put a h22 in. I want to put a b-series motor in there so i got another stock passenger top mount and i want to take off the one on the frame of the car and replace it with another passenger top mount. But Im not exactly sure how you swap these out? do you drill out the spot welds for the mount on the frame and it will come right off? And how do you re-weld the mount back on? align it up with the orignal holes and then weld around the mount?
Old Sep 28, 2005 | 11:07 PM
bump
Old Sep 29, 2005 | 09:35 AM
bump help
Old Oct 11, 2005 | 11:56 AM
dognutz's Avatar
If the mount is tack welded, you can carefully chisel the welds off. Just line everything backup carefully and weld away.
hondayute
Nov 13, 2007 08:47 PM
GSRswapandslow.
Mar 14, 2004 11:49 AM
