How does this sound..
Old Sep 27, 2005 | 11:02 PM
NerveAgent's Avatar
Default How does this sound..
I have 15x7 slips on my 96 civic cpe. I'm currently running 19/55/15. I was thinking of getting 195/50/15 or maybe 205/50/15. Im not dropped yet, but i do plan on a little drop. Its going to be with eibach pro kit. Its about a 1.5/1.0 drop. What size would be best for my car. I don't want any rubbing i don't wanna roll anything . Also whats the better bang for the buck the Toyo PROXES T1-R or dunlop direzza's
Thanks.
Old Sep 28, 2005 | 04:44 AM
Clay@tirerack's Avatar
Honda-Tech Sponsor
Default Re: How does this sound.. (NerveAgent)
I'd go with a 205/50/15 size. That will keep the overall diameter of the tire where it needs to be. I don't know much about the Toyo tires but the we have received very good reviews and feedback on the Dunlops. At $56 each they are a steal.
Old Sep 28, 2005 | 06:16 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: How does this sound.. (Clay@tirerack)
Assuming your Civic Coupe is an EX or an HX, I'd go with a 195/55/15 size. That will keep the overall diameter of the tire where it needs to be, as you can see by comparing these sizes:
185/65-14 (stock)
195/50-15 -3.4 percent
195/55-15 -0.1 percent
205/50-15 -1.7 percent
In 195/55-15, I would suggest the Yokohama AVS ES100 ($61 from the Tire Rack) or the Kumho Ecsta SPT ($67). Both offer great "bang for the buck", very good dry traction, outstanding in rain, and last a reasonably long time. If you don't mind spending a little bit more for better performance, then get the Toyo T1-R ($83 from onlinetires).
If your Civic Coupe is a DX, I would go with 195/50-15:
175/70-13 (stock)
195/50-15 +0.1 percent
195/55-15 +3.5 percent
205/50-15 +1.9 percent
In 195/50-15, if you buy before October 8, then I would get the Goodyear F1 GS-D3. It's better than any of the tires mentioned here (in fact, it's arguably the best street tire on the road today). It normally costs $83, but if you buy by Oct 8, there is a $75 gas card rebate that lowers the per-tire cost to $64, which is an awesome deal. The Toyo T1-R ($60 in this size) would be worth considering if you can't buy until after Oct 8. Either of these tires is better than the Yokohama ES100 ($59 in this size) or the Kumho SPT ($58), for about the same amount of money.
The Dunlop Direzza isn't available in either 195 size.
Old Sep 28, 2005 | 09:11 AM
NerveAgent's Avatar
where is this deal at? (goodyear)
Old Sep 28, 2005 | 09:38 AM
NerveAgent's Avatar
I found it nvm. Thanks!!!
Old Sep 28, 2005 | 12:28 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (NerveAgent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NerveAgent &raquo;</TD></TR><TR><TD CLASS="quote">I found it nvm. Thanks!!!</TD></TR></TABLE>
No problem. Anyone else, complete details are on the Tire Rack website here.
Old Sep 28, 2005 | 12:56 PM
highendmotorsports's Avatar
Default Re: (nsxtasy)
you will have no problems with eather size but I recomend going with 205/50/15. I set our costomers up with this set up all the time. never get any complants .
Highend autosports Mike
Old Sep 28, 2005 | 01:04 PM
NerveAgent's Avatar
You know i wouldn't rub, or you think i wouldn't rub. (1.5 drop) if 205 would rub i will not get it. Im leaning towards 195/55/15 right now.
Old Sep 28, 2005 | 01:17 PM
nsxtasy's Avatar
H-T Order of Merit
I don't think the 205/50-15 would rub, because its outer diameter is smaller than stock, even though the tread is wider.
I would still get the 195/55-15 though.
eg.reddragon
May 17, 2013 12:22 PM
A.E Motoring
17
Sep 23, 2004 03:56 PM
integraboi1010
Jun 11, 2004 10:33 AM
kinvid22
Mar 30, 2004 12:06 AM
BoostinEJ1
Mar 8, 2004 02:10 AM
