Remove ABS 94 EX
im just tired of messing with the abs system,it was working fine untill i did my swap. I swapped a diff motor and diff front brakes( JDM 94 del sol SI if that helps)i have to pump the brakes to stop and the ABS light is on...everything is hooked up right, ive been searching for a while on how to take out abs.. i cant find nothing on how to take it out... if anybody has a link of some sort that would be hella kwel...thanks in advnce
You need a different master cylinder, a different proportioning valve, and you have to change all of the front hard lines. Other than that, just follow the wiring harness and remove it.
mattcivic
Dec 7, 2006 02:03 PM
JimmyAtlantis
Dec 8, 2005 10:38 AM
