Newly aquired 93 HB need some info!!!
Old Sep 27, 2005 | 08:08 PM
S-fiend's Avatar
Default Newly aquired 93 HB need some info!!!
Well I just bought and towed home a 93 DX hatchback. Got it off a customer at work for only $300, body is in good shape and so is the int. considering its 12 years old. Only problem is the seized alt. pulley and blown headgasket. Besides for that it's in pretty good condition.
Now here's where I need some help. And of course I did the mandatoy searching first but unfortunately came up empty.
The car is now automatic. My goal is to swap in a 5-speed, build the block and head slightly with some porting and a turbo set up.
<U></U>Questions<U></U>
1. I thought the engine in the EG's were a D16Y8 but I'm not entirely sure. I'd appreciate it if someone could clarify this.
2. What is the code for the 5-speed manual trans from a 92-95 civic
3. Is the crank a 6, 7 or 8 bolt?
Thanks for the info and if your interested in my set-up I'll be running see below:
Engine:
-eagle rods (I know eagle sucks...)
-skunk2 race valve springs + retainers
-ARP studs
-port+polished: int. mani., head + TB
-new headgasket, seals and bearings
-14B turbo
-custom tubular exhaust manifold
-2.5" downpipe + full exhaust
-450cc DSM inj. + 10A resistors
-S-AFC
-EVO IIX FMIC
-Excedy stage II clutch + stock flywheel
Suspension:
-skunk2 camber plates
-skunk2 lowering spring
-KYB yellows
Exterior:
-HX wheels powder coated black
-JDM lip kit + rear spoiler
-ITR yellow paint
Interior:
-Roll cage
-2x tenzo R racing seats (black
-stripped int. (except: front seats, dash, center console, door panels and floor mats)
I'd like to put down at least 200whp at 10-12lbs of boost using just the AFC for tuning and be able to run 14's @ 90-95mph with DR's. In the future I plan on upgrading to a K-series engine (maybe a k24a2 or built k20a) and at least 12's on slicks (if not 11's), hence the use of a roll cage.
Any suggestions/comments are appreciated.
Old Sep 27, 2005 | 08:10 PM
G2 Speed's Avatar
Default Re: Newly aquired 93 HB need some info!!! (S-fiend)
Why do you need a roll cage if your only gonna have 200whp?
and you no if you don't wear a helmet witha rollcage, and get in an accidet you will hurt your self even worse..
Old Sep 27, 2005 | 08:13 PM
S-fiend's Avatar
Default Re: Newly aquired 93 HB need some info!!! (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">Why do you need a roll cage if your only gonna have 200whp?
and you no if you don't wear a helmet witha rollcage, and get in an accidet you will hurt your self even worse..</TD></TR></TABLE>
READ above.
Later I plan on going for 12's if not 11's with some K-series engine. I'm planning ahead but for now I have two D16's and I plan on using them first.
Old Sep 27, 2005 | 09:19 PM
underb00steg6's Avatar
first off the d16y8 do not come in Eg's. they come in 96-00 ex models ......second is what code are you looking for from the 92-95 civic ...ex ? dx ? and third question i have no idea what you're talking about...clarify?
machanicmaniac
Jun 14, 2016 04:00 PM
93grayeg
Nov 12, 2013 08:43 PM
retoddhatch
Apr 5, 2013 02:29 PM
FakinIt93FakeR
46
Nov 18, 2009 07:17 AM
lilredhatch
May 12, 2005 07:51 AM
