Compression ratio help and valvetrain questions
Old Sep 27, 2005 | 07:44 PM
SOHCD16y8's Avatar
Default Compression ratio help and valvetrain questions
Im building an LSVTEC with for my buddies car and this is my first true all motor build. I usually build turbo motors and go with lower compression. Its a B18b with 10.5:1 pistons and a b16a head. Stock HG thickness. Does anyone have an idea what the compression will be. The bottom end is balanced with eagle rods also. What head modifications are best to make within a reasonable price to make good horsepower in the 9000 prm range. Thanks for help
Old Sep 28, 2005 | 05:17 AM
iakona's Avatar
a lot!! stock CR on a B18B is around 9, and ls/vtec (depending on the head you use) raises this to almost 10.
try the CR calculator:
http://zealautowerks.com
Old Sep 28, 2005 | 05:18 AM
LSVTEC 91 Civic's Avatar
Banned
For the head I'd say get a good port and polish for the extra flow, and a set of nice bumpsticks to make that baby breathe. I have no idea how to calculate the CR with aftermarket pistons.
Old Sep 28, 2005 | 06:52 AM
dfoxengr's Avatar
Default Re: (LSVT3K 91 C1V1C)
you need the dome cc's
and the combust. chamber cc's, as well as the volume of the cylinders.
get a good valvetrain, and some cams. maybe a rocket complete head package would do you good. m22x's
Old Sep 28, 2005 | 05:40 PM
SOHCD16y8's Avatar
Thanks for the replies. I wasnt really sure about what the new pistons cc's will be, thats why I asked
Old Sep 28, 2005 | 05:41 PM
dfoxengr's Avatar
Default Re: (SOHCD16y8)
all are different.
Old Oct 4, 2005 | 05:43 PM
SOHCD16y8's Avatar
yeah I was kind of hoping that someone would know, thanks guys
Old Oct 4, 2005 | 06:03 PM
SOHCD16y8's Avatar
I just found it, its 5.7 with 30mm Comp height. This bring compression to 12:1. Is that too much for a daily driver? Yes it will be tuned.
Dawsonty
Sep 27, 2008 12:38 PM
EGB18
Jul 14, 2004 10:36 AM
SSS2000
Apr 4, 2004 08:42 PM
streetlvlhatch
Jan 22, 2004 09:55 AM
OBD-One-Kanobe
Sep 17, 2001 02:54 PM
