What kind of pistons to get?
For me its in between JDM ITR or CTR.. I only have 91 octane available for me so i'm leaning towards JDM ITR. One question....do toda A's respond well to 11.4:01 compression? Or would getting toda B's be better if i was going with JDM ITR pistons?
If you have a b18c block with a b18c1 head...CTR pistons will give you 12.3:1 compression, not 11.8:1. If you have only 91, then I would suggest that you stick with the JDM ITR pistons which would be about 11.4:1
I just posted something about this same topic a while ago, canuck is right, with the CTR pistons in the GSR block and head will net you 12.3 compression, a little higher than most people feel comfortable with. I personally would stick with something more modest, but that's me, I'm not looking for a monster that isn't safe to drive.
canuck-mx6: I think in order for me to run the ctr pistons in my block without detonating would be to retard my timing. But if i'm going to do that, would it defeat the purpose of raising my compression? Also, is 11.4:01 a good compression for aggressive cams, as in will i see a good gain?
There are a couple people on the board that I know are using CTR pistons, both with retarded timing. One running 12 degrees and the other 14 degrees of timing, so it can be done.
just because it can be done doesnt mean its wise....
12.3:1 compression on a daily drivn car is pretty harsh on your motor. the chance of detenation is very high. JDM ITR pistons would put the compression to about 11.3:1. same as if you were to put normal b16 pistons. that would give you about 11.3 as well.
Just compromise...JDM ITR & Mugen headgasket
How is 11.5:01 on a daily driver motor? Too harsh? This is on 91 octane, thanks for the help guys.
aris04
Jun 7, 2004 12:03 PM
