what is needed for a b18a swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sormeroid »</TD></TR><TR><TD CLASS="quote">sorry i only have the condom. i sold the pirate like 4 months ago.</TD></TR></TABLE>
then you are screwed aren't yaaa?
what are you even talking about. i have 3/4 of the stuff. except hubs and distributor. what kind of harnesses will i need and what kind of mounts and axles. will the stock linkage work.
Check the link in my signature...I have done this swap and wrote out pretty much what you need/don't need and what you need to do to do this swap
https://honda-tech.com/zerothread?id=1213345
what the hell do you mean by hubs? This is not a 88 hf crx.
use b series 94 and up integra 99-00 si axles, 94-up integra mounts. Modify your stock harness, b series shift linkage. Motor, hydo (not a1) tranny, and ecu obdI p74 or p75 or anything that chipped to run LS motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">what the hell do you mean by hubs? This is not a 88 hf crx.
use b series 94 and up integra 99-00 si axles, 94-up integra mounts. Modify your stock harness, b series shift linkage. Motor, hydo (not a1) tranny, and ecu obdI p74 or p75 or anything that chipped to run LS motor.</TD></TR></TABLE>
He can use 90-93 integra axles but he needs to use the integra intershaft
He dosen't need a stock b-series harness...the stock D-series will work
try this. all the info you need except the vtec part. it's just like installing a d series engine. you need the search button, engine, tranny, axles, ecu, clutch, hoses, wires harness, mounts, and shifter. all from the donor car. it's plug and play.
http://tech.hybridgarage.com/t....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">
He dosen't need a stock b-series harness...the stock D-series will work</TD></TR></TABLE>
yeah he can, but it's hard to find a 90-93 intermidiatte shaft, at least all that I came around here is 94-up. You are right I forgot about it.
And about the harness. That's what I said he can modify his stock harness.
Also about the tranny you will want to find the shortest tranny you can find for your money. LS tranny and no turbo = slow b. If it's turbo then it's a different story.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">Also about the tranny you will want to find the shortest tranny you can find for your money. LS tranny and no turbo = slow b. If it's turbo then it's a different story.</TD></TR></TABLE>
yeap...I know about the shorter gearing = better for racing but pain on the hwy.
axels left 92-93 integ right 89 integ chipped p28 or 95 ls ecu b series linkage 92-95 integ mounts integra throttle cable integra lower/upper hoses
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">axels left 92-93 integ right 89 integ chipped p28 or 95 ls ecu b series linkage 92-95 integ mounts integra throttle cable integra lower/upper hoses </TD></TR></TABLE>
you suck at writing information and you are trying to give mis-communication
he CANNOT use 92-95 mounts moron...this was tried and tested and there is NO WAY a 92-95 mount will have the motor sitting properly in the bay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">i got this swap u smart *** punk </TD></TR></TABLE>
I could give two ***** idiot. There is a LOT of mis-information on the net and I'm trying to save people time and money by giving out the CORRECT info
he CANNOT use 92-95 mounts moron...this was tried and tested and there is NO WAY a 92-95 mount will have the motor sitting properly in the bay</TD></TR></TABLE>
I think he ment 94-up.
