91 CRX HF my hood wont close a b series...
Old Sep 27, 2005 | 04:41 PM
hybridpatient95's Avatar
Default 91 CRX HF my hood wont close a b series...
i just installed a lsvtec in my 91 crx hf and im having trouble shuttin my hood.. it clicks but it doesnt lock all the way.. there's about a inch and a half space between the bumper and hood.. can you guys help me and show me what you did to make your hoods close lol.. very odd questions thanks guys!!
edit: has a eg radiator (half)
Old Sep 27, 2005 | 04:50 PM
crx2nr822's Avatar
Default Re: 91 CRX HF my hood wont close a b series... (frankenfiend 04)
The EG radiator is prolly whats keeping the hood from being closed......is it sitting right on the subframe or did u cut it to make it fit?
Old Sep 27, 2005 | 04:52 PM
EFRue57's Avatar
Default Re: 91 CRX HF my hood wont close a b series... (crx2nr822)
it's gonna be a tight fit anyways. what mounts are you using? my brothers ls/vtec hits the hood but it still closes all the way. he's using the hasport mounts. maybe the mounts you are using are making the motor sit at an awkward angle.
Old Sep 27, 2005 | 04:54 PM
crx2nr822's Avatar
Default Re: 91 CRX HF my hood wont close a b series... (EFRue57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">it's gonna be a tight fit anyways. what mounts are you using? my brothers ls/vtec hits the hood but it still closes all the way. he's using the hasport mounts. maybe the mounts you are using are making the motor sit at an awkward angle.</TD></TR></TABLE>
Good point also
Old Sep 27, 2005 | 04:58 PM
i got hasport mounts.. the motor sits straight.. and it did close before with a normal radiator.. so ima try making the eg radiator sit alot lower tomorrow.. any more suggestions.. would rasing the back of the hood on an angle help?
Old Sep 27, 2005 | 05:00 PM
kulangot's Avatar
did you take your hood off when you did the swap? maybe its not lined up write..or the EG radiator is hitting...
Old Sep 27, 2005 | 05:02 PM
yea i took the hood off... it looks to be right.. it clicks into it like its gonna close but then it just doesnt go anymore and there are marks from my eg rad.. so ima fix the sub frame tomorrow..
Old Sep 27, 2005 | 05:03 PM
EFRue57's Avatar
Default Re: (frankenfiend 04)
that might help but also might look funny. we are doing the jdm front end on his car though so we are hoping that will solve his problem. as for me with my b series i just have an ls motor that doesn't hit but is really close. i've decided against the jdm front but am going to get the VIS jdm stlye carbon fiber hood that has the hump rather than the dip and still fits the US front end.
Old Sep 27, 2005 | 05:18 PM
CRX Toad's Avatar
You need to dremel off a part of the hood skeleton. Then the hood will shut no problems.
Old Sep 27, 2005 | 05:29 PM
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">You need to dremel off a part of the hood skeleton. Then the hood will shut no problems. </TD></TR></TABLE>
thats done already... just need to make the radiator sit lower and im straight..
B16Drag
Apr 25, 2010 07:14 AM
88'CRXsi
Mar 2, 2008 08:21 AM
rhetorical
18
Sep 14, 2004 09:32 PM
hurleyburley
Feb 18, 2003 11:15 AM
ULTRA911
Oct 16, 2002 08:07 PM
