Can I run Stage 3 Intake Cam with Stock Exhaust Cam
Old Sep 27, 2005 | 04:30 PM
Power Rev Racing's Avatar
Default Can I run Stage 3 Intake Cam with Stock Exhaust Cam
Well I have a set of Skunk 2 Stage 3 cams, but the exhaust cam just broke. Can I run the Intake cam with my stock exhaust came?
Old Sep 27, 2005 | 08:43 PM
Default Re: Can I run Stage 3 Intake Cam with Stock Exhaust Cam (Power Rev Racing)
Up
Old Sep 27, 2005 | 09:06 PM
MONSTERZC's Avatar
you could run it but i dont think it would work well. you are getting air to head with the stage three cam but you aren't getting out of the head. really doesnt make since to me on why you would want to run it i would install the stock cams. since you are reinstalling the ex cam
Old Sep 28, 2005 | 05:26 AM
LSVTEC 91 Civic's Avatar
Banned
I ran a CTR intake with B16 exhaust cam a while back and made decent power, not sure how it would work with just the stage 3 intake cam since it's a pretty large cam. So, here is a free bump.
Old Sep 28, 2005 | 06:01 AM
Default Re: (LSVT3K 91 C1V1C)
I know alot of people do the CTR cam, but the skunk stage 3 is alot bigger
Old Sep 28, 2005 | 06:22 AM
CHEETAH's Avatar
only would work wll if you had a r/s ratio of about 2.0 or higher LOL.
I runt he skunk stg 2 exh cam with a jun3 intake cam and got really good results on my 92mm motor
Old Sep 28, 2005 | 06:40 AM
Default Re: Can I run Stage 3 Intake Cam with Stock Exhaust Cam (CHEETAH)
The motor is stroked.
Old Sep 28, 2005 | 11:50 AM
Rocket's Avatar
If you have higher compression 11.5+ I wouldn't do it. Your motor will retain too much heat and you'll be on the road to fuckedupmotorville .
Old Sep 28, 2005 | 04:14 PM
Default Re: Can I run Stage 3 Intake Cam with Stock Exhaust Cam (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">If you have higher compression 11.5+ I wouldn't do it. Your motor will retain too much heat and you'll be on the road to fuckedupmotorville .</TD></TR></TABLE>
Ok, Are you able to buy 1 cam from Skunk?
Old Sep 29, 2005 | 09:06 AM
Rocket's Avatar
Skunk dealers help here?
Old Sep 29, 2005 | 09:12 AM
Used2beAb16's Avatar
You could always look for like a blox. If you found like a blox or those other skunk knock offs you maybe be able to get one cheaper i really dont know. Just a thought.
nycjdmwhore
Apr 3, 2008 09:47 AM
Phrost
May 10, 2005 12:11 AM
H2nr
Feb 16, 2005 01:55 PM
knxtnh22accord
Jan 10, 2005 09:11 PM
Itz Darave
May 21, 2003 07:52 PM
