Transmission fluid question
Old Sep 27, 2005 | 02:00 PM
dynamo's Avatar
Default Transmission fluid question
I have a 2000 GSR motor in my hatch. I recently changed the tranny fluid, and topped it off with Honda's MTF to a point where the fluid was starting to leak out of the fill hole.
Yesterday I removed the passenger-side axle (with the half-shaft) because I need to replace it, and no transmission fluid came out after I pulled out the axle. Is this normal, or could this be a sign of a problem?
TIA
Old Sep 27, 2005 | 04:41 PM
Sam92Teg's Avatar
Default Re: Transmission fluid question (dynamo)
Well, did you jack up the side of the car you were working on, because that would cause the oil to go to the opposite side of the tranny instead of leaking out. I have done both axles numerous times and no oil ever leaks out.
Old Sep 27, 2005 | 05:19 PM
dynamo's Avatar
Default Re: Transmission fluid question (Sam92Teg)
Actually, the car is leveled perfectly with all four corners lifted up on jackstands. So sounds like it's perfectly normal that it did not leak? *Sigh of relief*
Old Sep 27, 2005 | 05:27 PM
memicah's Avatar
no man, what I think that guy is saying is that if you do one side at a time then the gravity will pull the oil toward the side of the car that is still sitting on the ground creating no leaks. correct me if I'm wrong.
Old Sep 27, 2005 | 06:25 PM
dynamo's Avatar
Default Re: Transmission fluid question (memicah)
Ok so I guess my question is should it drip out if the car is perfectly leveled?
Old Sep 27, 2005 | 06:50 PM
00IntegrAllmotoR's Avatar
HT Black OPs
yup!
Old Sep 27, 2005 | 10:51 PM
dynamo's Avatar
Default Re: Transmission fluid question (00IntegrAllmotoR)
So any ideas what I should check for now, other than fluid level in the tranny (although I know for a fact I topped it off 2 weeks ago, and there are definitely no leaks).
shadohconspiracy
13
Nov 4, 2007 08:32 AM
Linh.
May 25, 2007 11:07 AM
nexgen91
16
Apr 16, 2007 10:04 AM
4doorH22
Nov 21, 2002 09:38 PM
