is it safe to pull the injectors and start the car to see if they work?
just wondering and trying to find out why my 90 DA isnt starting and was just wondering if it safe to pull the injectors and crank the engine to see if the injectors are the problem. if there is an easier way please let me know.
i have spark, the fuel pump pressurizes, and there is fuel in FPR. could i check the spark plugs to see if fuel is on them? the car will just crank but wont kick over and start.
when i take the vacuum line off fuel comes out of both the line and from the fpr
ok so you have any good ideas on how to check to see if fuel is makin it to the cylinders. becuase im drawing blanks
you could spray in some starting fluid and see if it does anything. i would replace the bad fpr and go from there
a generic drawing but shoudl get the idea across
Rikaro
Sep 25, 2009 11:36 PM
Christopherian1982
Dec 31, 2008 08:17 AM
TeamCracka
Apr 28, 2004 06:55 AM
