Air conditioning temp slider is really stiff.
Old Sep 27, 2005 | 10:34 AM
Nataku's Avatar
Default Air conditioning temp slider is really stiff.
well... the switch on my ITR climate control of the air temp hasn't worked since I bought the car a couple of weeks ago. If you move the slider to hot... it moves t's way back to cold by it's self.
Today I took apart the unit and found that the cable attached to the slider wasn't on quite right... i reatached it and put the unit back in the dash and the cable is really har to move... meaning the slider is now hard to move...
anyone else had this problem and/or fixed it?
Old Sep 27, 2005 | 10:41 AM
2G0S0R1's Avatar
New User
Default Re: Air conditioning temp slider is really stiff. (Nataku)
My two integras are both hard to move... but not too hard. If someone put in a new stereo they may have messed with it. If it isnt routed properly (in a straight line) to the actuator arm then it will be more difficult. Also, try to lube up all the joints... especially the heater core bypass valve in the engine bay, by the firewall.
Old Sep 27, 2005 | 11:05 AM
Nataku's Avatar
Default Re: Air conditioning temp slider is really stiff. (2G0S0R1)
i disconnected the cable from everything and pulled it by hand... the cable doesn't want to slide through the tubing.
Old Sep 27, 2005 | 11:51 AM
iH8RICERZ's Avatar
you could either try lubing it up a little or buying a new one. When I first bought my teg, i could barely slide that sucker across..one night, i actually broke the **** off! A little bit of lube should do it
Old Sep 27, 2005 | 02:23 PM
purejdmsi's Avatar
Default Re: Air conditioning temp slider is really stiff. (iH8RICERZ)
94 gsr smae problem if you find out what it is let me know
Old Sep 27, 2005 | 02:29 PM
Nataku's Avatar
Default Re: Air conditioning temp slider is really stiff. (purejdmsi)
anyone recomend a lube? i wonder how to get it down far in the tubing...
no not KY :-P
Old Sep 27, 2005 | 02:43 PM
phateless's Avatar
tri-flow. go to a bicycle shop and pick up a little bottle for about $4.00. this **** works wonders!!!!!!
Old Sep 27, 2005 | 03:27 PM
2G0S0R1's Avatar
New User
Default Re: (phateless)
Once I had to disassemble my climate controls to get in there because the lil wire bent up inside (from jamming on the **** while stuck)... it was a bitch to say the least.
Tri-flo is good stuff... Smells funny, but has masss teflon.
Old Sep 27, 2005 | 05:30 PM
phateless's Avatar
i remember years ago i used tri-flow on the clutch cable of my 88 jetta. WOW, did that feel good!
Evolution-93-Ex
Jul 31, 2009 03:25 PM
Hairy Gorilla
Apr 26, 2005 09:26 PM
yOnKiNaToR
Mar 11, 2005 04:12 PM
TheIceMan
Feb 20, 2005 02:20 PM
