Questions: Half size aftermarket radiator/o.e.m on F.I. prelude
Old Sep 27, 2005 | 10:18 AM
btrim23's Avatar
Default Questions: Half size aftermarket radiator/o.e.m on F.I. prelude
I've done search but no results regarding prelude chassis/engine using the half size radiator. If you're turbocharge, is it safe to use the half size radiator (even aftermarket or o.e.m) ? Opinion please.
Old Sep 27, 2005 | 12:34 PM
flip1199's Avatar
Default Re: Questions: Half size aftermarket radiator/o.e.m on F.I. prelude (btrim23)
the supports arent goin to line up but that's nothing zip ties can't fix. and you should be fine with a aftermarket half sized rad as long as u have a good fan.
Old Sep 27, 2005 | 06:53 PM
planeman01's Avatar
c61lude runs a pwr half size on his boosted 5th gen with a FAL fan and dosn't have any problems
Old Sep 27, 2005 | 07:52 PM
btrim23's Avatar
thanks, I figure it shouldn't give you any problem as long as there's coolant. I've seen a lot of h22 swap civic used so I figure there's not a problem with it.
Bsmith1010
27
May 15, 2019 07:23 AM
Detman101
Aug 26, 2011 12:41 PM
munky_350
Jul 17, 2008 08:09 AM
lude-n-da-works
Dec 13, 2006 08:50 PM
ultradx
Aug 14, 2005 07:00 PM
