what axles???
Old Sep 27, 2005 | 10:06 AM
.Grimace's Avatar
footwork mastery
Default what axles???
if i have a b16 swapped into my CRX what axles do i use??? do i use the 90-93 integra ones???
Old Sep 27, 2005 | 01:34 PM
user 72830283's Avatar
yea most likely the 90-93 non-abs ..but if you've got the SH3 intermediate shaft..u might need the 86-89 ....
i'm going through the same issue...if this helps any..
https://honda-tech.com/zerothread?id=1381465
Old Sep 27, 2005 | 05:46 PM
virginia_dude's Avatar
Default Re: what axles??? (TougeCRX)
90-93 Integra Non-abs axels if you are using the Integra intermediate shaft also...this combo does not work with the SiR intermediate shaft as its about an inch too short for the Integra Axel on the drivers side.....try it and you will seperate the CV joint at some point.
Old Sep 28, 2005 | 09:41 PM
.Grimace's Avatar
footwork mastery
Default Re: what axles??? (virginia_dude)
thx everyone, so if i had a ls tranny good chance i have integra intermediate shaft???
Old Sep 28, 2005 | 09:43 PM
yea if its the tegra LS you're talking about...you probably have the SK7 half shaft allowing you to use the 90-93 teg axles..but keep in mind 94' and up axles and half axles are different
Old Sep 28, 2005 | 09:52 PM
.Grimace's Avatar
footwork mastery
Default Re: (pr3d)
alright 90-93 i will go get these tomorrow. 94 and up are different cause they had abs right???
Old Sep 29, 2005 | 08:28 AM
well not entirely ...since the 90-93 tegs also came with ABS, but when you go to the store they'll ask you if you want the axle with that ABS speed sensor ring thing or not..just say non-abs axle..
HamiltonRex
Feb 22, 2006 03:58 AM
88ED8
Feb 6, 2005 07:29 PM
XANDER-666
Oct 7, 2002 12:04 PM
juicy.koreans.suck
10
Jan 10, 2002 10:47 AM
