H22 CAMS
Old Sep 27, 2005 | 09:53 AM
crxh22a4's Avatar
Default H22 CAMS
For a stock h22 what cams would you run???
Old Sep 27, 2005 | 10:22 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: H22 CAMS (crxh22a4)
Far as I know dont ya need a upgrade on Valvetrain , VS and R to run the type s cams?
Old Sep 27, 2005 | 11:56 AM
crxh22a4's Avatar
Default Re: H22 CAMS (ExplicitSpeed360)
I did,but i have a friend that has type s cams with no mods to the valve.
Old Sep 27, 2005 | 12:08 PM
Adam.'s Avatar
I put down 204 w/ Rocket Regrinds, I'd get them again if I was putting them on a stock h22.
Old Sep 27, 2005 | 02:25 PM
dfoxengr's Avatar
Default Re: H22 CAMS (DarkKnight1)
im buying my rocket H22x's soon already have rocket valvetrain
Old Sep 27, 2005 | 03:13 PM
TrackSpeedRacing's Avatar
Default Re: H22 CAMS (dfoxengr)
H24x's
Old Sep 27, 2005 | 07:13 PM
hondaballs's Avatar
crower stage 3
Old Sep 27, 2005 | 08:00 PM
aaaabbbb's Avatar
Do not purchase anything from me. -HT Staff
h24x baby
Old Sep 28, 2005 | 04:15 AM
Adam.'s Avatar
Default Re: (THC_H22 PROJECT)
Do you guys actually have the r/m cams yet? If you haven't had them and dyno tested them then you are just going by brand name appeal and you should stop. We have enough of that on h-t as it is.
Old Sep 28, 2005 | 04:17 AM
dfoxengr's Avatar
Default Re: (DarkKnight1)
whats your setup darknight with the regrinds?
Old Sep 28, 2005 | 04:37 AM
Adam.'s Avatar
Default Re: (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">whats your setup darknight with the regrinds?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1253111
Old Sep 28, 2005 | 06:37 AM
dfoxengr's Avatar
my setup in the works is very similar.
but with the addition of my designed IM/header, head mill, not sure how much yet (~11:1). hybrid-racing b tranny adapter kit, h22x cams, 70 or 72mm TB, and my port job. should be interesting, i think i can pull out 220 with a good tune.
was yours on a dynojet?
Old Sep 28, 2005 | 06:56 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">my setup in the works is very similar.
was yours on a dynojet?</TD></TR></TABLE>
Yes. I actually was hoping for a bit more, but they are very mild cams (regrinds tend to be that way). For what they are, they probably netted me another 3-5whp. If I was looking for something very close to stock, I would pick the regrinds.
Old Sep 28, 2005 | 06:59 AM
dfoxengr's Avatar
good motor no doubt though right?
have you timed it yet?
if so whats the car setup as well.
Old Sep 28, 2005 | 07:09 AM
Adam.'s Avatar
Haven't been to the track since the cams. Also I just swapped it from an 2550lb coupe to a 2150lb hatchback so I'll never know the real gains from the cam swap.
Old Sep 28, 2005 | 01:44 PM
dfoxengr's Avatar
what were your old times?
Old Sep 28, 2005 | 03:44 PM
aaaabbbb's Avatar
yes i actually have to cam.. getting ready to dyno tune.. ill keep u posted on wut it pushes out
Old Sep 29, 2005 | 12:31 PM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">what were your old times?</TD></TR></TABLE>
Before the cams I was putting down around 198whp. Afterwards, 204whp. My best times were 14.0s, but it was a 13.9 car w/a better(slimmer) driver.
94sisol
Sep 22, 2006 12:10 PM
94sisol
Sep 22, 2006 10:11 AM
dayne808
Jul 28, 2005 09:00 PM
crxhybrid85
16
Jun 28, 2005 06:53 AM
