check engine light came on the other night
Old Sep 27, 2005 | 09:30 AM
sleeperteg's Avatar
Default check engine light came on the other night
so the light came on but ive been told by many that its just a mileage thing in most cases that sets that lil bastard off... just to make sure im ok, what usually is scheduled for the teg at around 111,000 miles on it? tune up? timing belt? anyways i had my buddy help me find the switch cuz that shyt was getting annoying, but i want to know if its something i should look into or just keep driving. The car isnt acting up in any way so i think i should be ok but i dont want to run until somethin goes really bad either.
thanks in advance.....
Old Sep 27, 2005 | 10:27 AM
mastamind's Avatar
Default Re: check engine light came on the other night (sleeperteg)
Are you talking about the "required maintenance" light? If you do in fact have a check engine light, post up the code and I could give you some feedback on it.
Old Sep 27, 2005 | 10:59 AM
Marauder's Avatar
Default Re: check engine light came on the other night (mastamind)
check engine light means something isn't working.
Pull the code and find out what's wrong
Old Sep 28, 2005 | 09:22 AM
sleeperteg's Avatar
Default Re: check engine light came on the other night (Marauder)
boy dont i feel stupid.... yea i meant to say the maintinence req'd light....lol sorry fellas wasnt thinkin straight when i wrote tha post....
Old Sep 28, 2005 | 09:23 AM
IntegraLs97's Avatar
same here but mine just blinks the turns off.
Old Sep 28, 2005 | 10:10 AM
mastamind's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperteg &raquo;</TD></TR><TR><TD CLASS="quote">boy dont i feel stupid.... yea i meant to say the maintinence req'd light....lol sorry fellas wasnt thinkin straight when i wrote tha post.... </TD></TR></TABLE>
I figured that's what you were talking about. This is the 112,500 mi. recommended service for a Integra:
Replace engine oil and filter.
Inspect front and rear brakes.
Check pads and discs for wear (thickness) and damage.
Check calipers for leaks and check tightness of mount bolts.
Inspect tie-rod ends, steering gearbox and rack boots.
Check steering linkage for looseness.
Check fluid lines for damage and leaks.
Check condition of rack boots.
Inspect suspension components.
Check bolts for tightness.
Check condition of ball joint boots for deterioration and damage.
Inspect driveshaft for cracks and check boot bands for tightness.
Old Sep 28, 2005 | 10:15 AM
.brian.'s Avatar
here ya go, read both of these links.
http://www.team-integra.net/se...D=483
http://www.team-integra.net/se...D=164
first one explains the light, second tells you how to turn it off.
Old Sep 28, 2005 | 05:11 PM
White cracker yeehaa's Avatar
maint. req. light is to tell you to change the engine oil, once you change it you can reset it, the box is located under the plastic dash part that is under the sterring wheel on the bottom right hand side (while sitting on the drivers seat), there is a button you press and it will reset it...
Old Sep 29, 2005 | 06:45 AM
sleeperteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mastamind &raquo;</TD></TR><TR><TD CLASS="quote">
right on fellas.....
6KVtec
Honda S2000
27
May 13, 2013 11:12 AM
Corruption
Jun 3, 2006 12:08 PM
jorge99hx
Nov 4, 2005 08:29 PM
VTECVillain
Jan 6, 2002 11:40 AM
