I need a Transmission Type R
Old Sep 27, 2005 | 07:58 AM
hondastreet's Avatar
Default I need a Transmission Type R
Is it possible to buy a complet tranmission brand new better than the type R spec.
Old Sep 27, 2005 | 07:59 AM
Dave_B's Avatar
Money makes the world go round. You can buy whatever you want if you have the cash. Have you searched this at all?
Old Sep 27, 2005 | 08:11 AM
i found this
http://www.passwordjdm.com/pro...D=359
ATS close ratio gear set for B-Series trans
Home > Engine Parts / Swaps > JDM engine parts > Honda > Transmission > ATS close ratio gear set for B-Series trans
Product condition : New
ATS close ration gear set for B-Series transmission
- Improve your lap time with close ratio gears
- Keep the Rev at the most powerful range-VTEC is fully utilized
- Can be combined with the ATS Final Gear
1st - 3.077
3rd - 1.652
4th - 1.308
5th - 1.033
Modified by hondastreet at 5:25 PM 9/27/2005
Modified by hondastreet at 5:43 PM 9/27/2005
Old Sep 27, 2005 | 08:34 AM
Dave_B's Avatar
My ATS 4.9 FD just came in a few days ago. But I thought you wanted a complete, don't have to do anything to trans right?
Old Sep 27, 2005 | 08:40 AM
This kit use the same gear type R spec for the 2second speed.
It's really expensive, 1360$ for the kit (1-3-4-5) and i need to buy all syncro (900$ i suppose), final drive (800$), LSD (1300$), second speed honda type R(400$) and the box (50$ use, i suppose)!!!
And i forgot the main shaft and second shaft
Old Sep 27, 2005 | 08:42 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (hondastreet)
Buy an ITR trans from honda, its like 1500 bucks.
Old Sep 27, 2005 | 08:44 AM
Ya so, i think that i will buy a brand new Type R transmission and i will change only the final drive.
It's the best way, I think
Old Sep 27, 2005 | 08:47 AM
cool guy name
What final drive are you looking for? 4.4, 4.7, 4.9?
Old Sep 27, 2005 | 08:51 AM
Dave_B's Avatar
Just buy the ITR trans and get an FD. Len can get you the trans and then you can install the FD and your done. LSD, 4.9 FD and a decent trans.
Old Sep 27, 2005 | 05:28 PM
ya, I will buy a 4.9 FD,
Presently, i have 97 spec type R JDM, 4.4FD. The 4speed and 5 speed spec ratio are different if you compare with USDM tranny.
So, i will buy a tranny 2001 spec USDM, with 4.7FD
Old Sep 27, 2005 | 05:58 PM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastreet &raquo;</TD></TR><TR><TD CLASS="quote">
So, i will buy a tranny 2001 spec USDM, with 4.7FD</TD></TR></TABLE>
Just as an FYI, you have that backwards.
Stock USDM is 4.40 ratio. Stock JDM is 4.78 ratio.
Old Sep 27, 2005 | 06:31 PM
Runnerdown's Avatar
Default Re: (George Knighton)
97 jdm type r is 4.4 fd. I believe it was 99 when 4.78 started.
EDLOVA23
Mar 25, 2011 01:13 PM
Honda Bull
Transmission & Drivetrain
10
Apr 1, 2009 02:49 PM
Suprdave
Aug 13, 2004 02:20 PM
