vis trunk owners stand up
hey guys got a quick question anyone have a vis trunk for the 4g? i just recieved mine .. but i didnt realize you have to use the stock licence plate holder thingy off the old trunk.. is this how its gonna be?
Pic:
Pic:
Yeah, that's how they do all their trunks. You just get the metal part and you have to attach all the plastic stuff and locks and such...
I really want to get one of those myself. What does it weigh compared to stock??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Yeah, that's how they do all their trunks. You just get the metal part and you have to attach all the plastic stuff and locks and such...
I really want to get one of those myself. What does it weigh compared to stock??</TD></TR></TABLE>
I'd like to know the weight difference also seeing as the stock trunk is pretty light already. $400+ is a good chunk of change for just a lil show...
I would estimate that any difference in weight is negligable. It really doesn't make any more difference in weight then if you had just taken a **** or if you're holding it all in....think about that.
so if you really want to go faster...poop.
just from lifting it i gotta say its not much lighter than the stock one. but i'll get some real weights when i install it
yeah the weave isnt perfect. i noticed that too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitownrida »</TD></TR><TR><TD CLASS="quote">just from lifting it i gotta say its not much lighter than the stock one.
Seriously??!?
Seriously??!?
Ya I was pissed when my 4th gen lid showed up without the liscense plate box and my buddies one for his civic did . I sent mine to a shop and had teh box overlayed in cf . It looks alright but not perfect
you will save about 10lbs or a little more...but the only downfall in having a cf trunk is...when you pop the latch from the driver side, the trunk flies open real fast because it is sooo light. (if your friend stands in front of the trunk when you open it...be careful, it might knock em out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 »</TD></TR><TR><TD CLASS="quote">but it looks sooo nice...
A little OT, but has anyone ever seen a 4th gen with the black-top scheme like on civics, with the CF hood & trunk, with the roof painted black?
</TD></TR></TABLE>A little OT, but has anyone ever seen a 4th gen with the black-top scheme like on civics, with the CF hood & trunk, with the roof painted black?
I met someone with a 4th gen with a VIS trunk, and all you have to do for spring tension is take out one of the two springs. They are pretty easy to remove. One spring barely holds it up, so it stays at any angle you put it.
Plus, then you can put ONE super-deep speaker in there.
i already have the cf hood, i wanted to get the trunk too. n to finish it off, not to have the roof painted black but to get that cf insert for the sunroof, like on steve oaks car. i think that would be sick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93boostedLUDE »</TD></TR><TR><TD CLASS="quote">i already have the cf hood, i wanted to get the trunk too. n to finish it off, not to have the roof painted black but to get that cf insert for the sunroof, like on steve oaks car. i think that would be sick</TD></TR></TABLE>
Ditto, I plan on doing that someday since my hood is in sad shape, my wing is fiber blooming, and the sunroof insert saves some serious weight. I'll replace those items with carbon fiber & expect it to look nice & save me close to 50lbs.
VIS products are more concerned with looks and mass production than the lightest / strongest product .. lucky for them tho c/f ends up lighter than metal no matter how you put it together ..
IMO .. JSP makes lighter / stronger products .. there stuff is often over looked but should probably get more attention from tuners looking to build true performance vehicles ..
They make hoods for the 4th gen .. and hoods and trunks for the 5th gen ..
heres some Q & A from the JSP FAQ ..
1. Why aren't the edges on your hoods and trunks "rolled" like other manufactures?
Most rolled edges out on the market are nice to look at but they reduce the integrity and durability of your hood or trunk. These "rolled" edges are thicker than the rest of the part; therefore the part will react differently in those areas over time due to temperature changes (winter/summer). This usually leads to yellowing or clouding edges, as well as brittle edges that are easily chipped or cracked. Most rolled edges also incorporate a lot of body filler or putty to carry the rolled look over to the inner frame of the hood/trunk; and as we all know putty and or body filler adds weight and is not desirable on any component of an automotive body. These are just a few reasons why we choose not to incorporate rolled edges in our products.
4. Are your products really manufactured in North America or do you just re-pack and claim them to be made in North America?
All products are 100% handcrafted in North America; we do not have our product made overseas and re-pack here then claim them to be North American made.
6. Will my hood/trunk yellow or start to loose its clarity after it's exposed to the sun?
No, all surfaces exposed to the sun are manufactured with materials that contain UV stabilizers, and each hood/trunk is further protected with a UV stable clear coat.
.. I donno about anyone else .. but my VIS c/f hood yellowed around the edges after tjust the first month. And got small dents all over it .. (weak wet carbon) ..
Don't get a CF sunroof plug because it "looks sick". It completely removes the use of your sunroof and you should only do it if you want to loose weight.
