clutch adjustment
Old Sep 27, 2005 | 07:01 AM
trianglegreg's Avatar
Default clutch adjustment
my clutch wont adjust from hte tranny ive tighten the adjusting know all the way then i tried loosening it all the way then i tried mid way, but still has no affect on where my clutch is engageing.... reason why im doing this is because my clutch is real loose and it engages way at the top of the peddle. Was wondering if there was a way to adjust the clutch from the pedel if you can how??
Also if anyone knows how to adjust the idle when the car is warm that would be great, i dont know where the adjustment screw is...
Old Sep 27, 2005 | 07:08 AM
Crimson_Tide's Avatar
Default Re: clutch adjustment (trianglegreg)
bump for an answer... i just changed my clutch cable and before it would engage almost immediatly and thats the way i like it... i didnt think to look at my old cable before i threw it away ... now im stuck with it engaging at the top of the pedel
-Josh
Old Sep 28, 2005 | 06:27 AM
Default Re: clutch adjustment (Crimson_Tide)
bump for an answer
-Josh
Old Sep 28, 2005 | 09:49 AM
jdeemseerx's Avatar
well does your clutch slip? how many miles are on the clutch? loosening and tightening the adjustment screw on the clutch cable should change where the clutch engages..if not you might have a stretched cable as for pedal height you have to play around wit the nuts on the back of the clutch pedal assembly..you want it to be even wit the brake pedal at least thats where i like mine to be..it might be time for a new cable i was havin probs wit it engagin all the way at the top..replaced the cable and bingo now it engages about 2 inches from the floor the adjustment screw for your idle is on the throttle body its a flat head screw but if your idle is jumping or fallin you could have a clogged IAC
Old Sep 29, 2005 | 09:50 AM
Default Re: (jdeemseerx)
thanks for the advice i put a b16 in my crx and it wasnt going in gear at first so i replaced the clutch and that fixed it but its getting harder to put in gear now it has something to do with the cable it might be that it is stretched, ill look into it
Haarstad
Jun 24, 2012 09:50 PM
danno33
Jul 14, 2009 07:45 AM
MichealSenior
Feb 17, 2009 12:56 AM
tigueremalo
Jan 14, 2007 02:29 PM
DroppedTegLS
Sep 28, 2002 01:51 PM
