Just swapped the EK and have some ?'s
Old Sep 26, 2005 | 10:11 PM
ThefirstPACT's Avatar
Default Just swapped the EK and have some ?'s
Well i put a b20 in the hatch today and everything went pretty smoothly...I just want to know what I should do about my O2 sensor placement and my lack of a cat! Will i need to have the 2nd O2 after a cat? Will i have a CEL still on even if both O2's are in the exhaust? This is my first OBD-2 swap, i was a HUGE EF/DA fan so...i am moving on up and learning as i go! Thanks in advance! Also is there any draw back to extending O2 sensor wiring? I will heat shrink and solder them if that makes a diffrence!
I am done!
Dutch
Old Sep 26, 2005 | 10:40 PM
dat_flip's Avatar
Default Re: Just swapped the EK and have some ?'s (ThefirstPACT)
you need to wire in the o2 sensor/plug to the harness.
Old Sep 26, 2005 | 11:29 PM
Default Re: Just swapped the EK and have some ?'s (dat_flip)
i this lawrence? This is dutch man. I have the O2 sensors but i just need to get the O2 sensor bungs welded in before i head back home! I have no cat and i just want to know if i will keep throwing a CEL if i dont have a cat? I also got all your stuff no one in town had the valve cover grommet things on top...dont knwo what there called. It was like 55bucks and some change just hit me back with 50 since you got my in n' out that one night! I will hit you up when i get back to check out the swap! Also what throttle cable do i need?
Dutch
Old Sep 26, 2005 | 11:35 PM
u2civic1's Avatar
there a resistor somehing u can install to trick the o2 is working
also i heard that u can put the second o2 in foil to track the ecu
Old Sep 26, 2005 | 11:37 PM
dat_flip's Avatar
check your pm
pizzamanprelude
Aug 2, 2006 03:26 PM
noopsITR
May 11, 2006 11:26 AM
EJAYATE
Jun 1, 2005 03:51 PM
s.cali alan
May 28, 2004 12:39 AM
shivers
Apr 19, 2002 06:05 AM
