door locks all fucked up
my auto door locks are not working and its not the fuse i don't know what to do i took my door panel apart and nothen looks messed up what should i do
Modified by hondabum4life at 11:12 PM 9/26/2005
are u trying to unlock it from your remote on your key? if so mabey the battiers are drained.. *Shrugs* not to sure, sense i dont knwo the year, model, ect on yoru car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabum4life »</TD></TR><TR><TD CLASS="quote">my auto door locks are not working and its not the fuse i don't know what to do i took my door panel apart and nothen looks messed up what should i do
Modified by hondabum4life at 11:12 PM 9/26/2005</TD></TR></TABLE>
Take it to someone who knows what they're doing.
that did not help, my locks work every blue moon, but they dont make any noise i just does not work. is it still the actuator should i just replace it and see if that works?
thanks any way
, it sounds like accords all have about the same problems. its nice that there not big problems but still its the little things that get to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabum4life »</TD></TR><TR><TD CLASS="quote">that did not help, my locks work every blue moon, but they dont make any noise i just does not work. is it still the actuator should i just replace it and see if that works?</TD></TR></TABLE>
you might want to do some diagnostic before replacing the actuator , it could very well be the actuator but it could also be the power door lock control unit..............bang on it a few times and see if door locks work it is located in left frt door, under door panel ''...If still no work you need to chk if you are getting power and ground at driver's actuator before you condem it...
thanks deserthonda you are always so helpful, i did try to bang on it, that was the first reaction i had, of corse i do that with everything, my tv, my alarm. i will try and see if its geting power thats probly it because sometimes it does work it seems like when it rains it works
i neet to go get a volt tester but thanks man i will try that.
John A. Parker
Apr 10, 2017 10:00 AM
Btothe3rdDegree
Jul 13, 2004 12:25 PM
