B18 swap to 94 Civic Vacuum Setup
Old Sep 26, 2005 | 09:00 PM
94B18Civ's Avatar
Default B18 swap to 94 Civic Vacuum Setup
I need a vacuum diagram for a 98 acura integra ls with a b18b1...its in a 94 civic coupe....sounds like vacuum problem but all advice will be helpful...it has a rough idle jumpin from 500 to 1000rpm...help plz
Old Sep 26, 2005 | 10:49 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: B18 swap to 94 Civic Vacuum Setup (94B18Civ)
That could be anything. I can give you a Vaccum diagram. There are 3/4 on the intake manifold. The one that goes to the brake booster, the one that goes to the fuel pressure regulator and possibly one that goes to the map sensor, if it is not attached to the throttle body. There is also the PCV system that usses vaccum as well. Thats about it as far as lines go.
tundra2000
Jun 17, 2010 01:48 PM
h22_crx
May 11, 2008 06:22 PM
B16A CRX
Mar 20, 2008 04:53 PM
smash fascism
Apr 22, 2005 03:48 AM
95TegGSR
Jun 19, 2002 06:07 PM
