What size Socket for D16y8 motor mount screws?
Old Sep 26, 2005 | 08:42 PM
Civic4less's Avatar
Default What size Socket for D16y8 motor mount screws?
I couldn't find a socket i had for those screws so I gotta ask a friend for one but I dunno what size it is. Does anyone know?
Old Sep 26, 2005 | 08:46 PM
jameskersten1's Avatar
if you are thinking the trans and front mount (t/belt side), i am pretty sure its 17mm but i am not positive.
Old Sep 26, 2005 | 08:47 PM
Civic4less's Avatar
Default Re: (jameskersten1)
The one on the Trans side and the one on the right side... right by the timing belt cover.
Old Sep 26, 2005 | 08:49 PM
Default Re: (Civic4less)
yeah i think its a 17mm. Its that or 19mm. get your friend to bring both,
Old Sep 26, 2005 | 08:52 PM
KURUPTinc's Avatar
the actual bolts that go through the mount are 17 the ones that hold the mounts to the tranny are 19 the one that holds the mount brackt to the side of the timing cover are 14 but the mount is 19
Old Sep 26, 2005 | 09:14 PM
Luserkid's Avatar
Default Re: (KURUPTinc)
Your talking about torque mount bolts? The ones that go under the chassis area and bolt up right?
The one thats connected to the tranny is 3 17mm bolts and 2 14mm (under the chassis.
The one on the engine side is held on by 4 14mm bolts and 2 14mm under the chassis.
Old Sep 27, 2005 | 06:14 PM
Civic4less's Avatar
Default Re: (Luserkid)
Thanks a lot guys.
Kingkoopa20
Aug 27, 2008 07:02 AM
hndata9600
May 26, 2007 06:08 AM
iceman24
16
Apr 6, 2005 06:02 PM
qwklude82
Dec 28, 2002 05:44 AM
