i think i over-revved my motor
Old Sep 26, 2005 | 08:31 PM
civiccoupe94's Avatar
Default i think i over-revved my motor
i was getting on the highway on third, and i was going about 60 mph (was at 5,000 rpm) cause i need power and flooring it. i was switching to 4th, but i accidently switched to 2nd and flooring it, so i watch my revs went up to 7,600 for about 3-5 seconds. its a 94 D15b7 motor, and my guage cluster is a EX cluster, so i was right at the beginning of the red line. but i know the Z6 has higher revs, and i dont know the red line for a dx motor is.
after i came back, i was listening to the motor and it sounded fine, but i dont want to drive in the middle of the freeway next week having a blown motor or something.
Old Sep 26, 2005 | 08:46 PM
peacexisxfree's Avatar
you'd know if it was blown...believe me, you wouldn't be driving it. your oil ok? all other fluids ok? any smoke coming from the exhaust? any fluids where they shouldnt be? any funny smells? check all those things for sure. if you really want piece of mind, go get a compression test done.
Old Sep 26, 2005 | 08:48 PM
jameskersten1's Avatar
if you caused any damage you would have noticed by now. Its pretty commen for people wth preludes to down shift 5-2 by accidend and float a valve. you will notice right away though. I wouldnt worry about it
Old Sep 26, 2005 | 08:50 PM
fizeks's Avatar
Default Re: i think i over-revved my motor (civiccoupe94)
redline for d15b7 is 6,200 rpms.. but damn.. 7,600?rpms? not to sound like an *** but i dont understand why it took u 3-5 sec to switch it out of gear? but if everything sounds fine nothing should be wrong then..
Old Sep 26, 2005 | 09:15 PM
it took 3-5 secs cause i was on the highway, and my stero was on full blast, so i look at the tach and while i was flooring it, and i was like oh ****!
Old Sep 26, 2005 | 09:16 PM
komat's Avatar
Default Re: (civiccoupe94)
wouldnt the rev limiter kick in and drop it back down to whatever is the limiter is
Old Sep 26, 2005 | 09:30 PM
GdmLaz's Avatar
exactly do what i was thinkin how did u hit 7,6 on a dx ecu unless is chipped or sumthing
Old Sep 26, 2005 | 09:38 PM
nah its all stock, only i/h/e, the rev limiter was on i think, but i dont know because i hit the clutch right when i saw it at 7,600 and my stero was all the way up.
i was going about 60-65 i think on 2nd so i tihnk the engine was engine braking at 7,600 rpm, not because of me flooring it to 7'600 and rev limiter letting it go there.
Old Sep 26, 2005 | 09:44 PM
toeknee360*'s Avatar
well i was shifting 3rd to 4th in my ls/vtec at 8 grand and it accidently went into 2nd.. but i took it out quick.. everything is ay ok tho. compression all good, no noises or fluid drippings and ****
i got lucky
Old Sep 26, 2005 | 10:31 PM
dantastic's Avatar
Default Re: (Slammed92hbonN20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 &raquo;</TD></TR><TR><TD CLASS="quote">exactly do what i was thinkin how did u hit 7,6 on a dx ecu unless is chipped or sumthing</TD></TR></TABLE>
a mis-shift will make your engine turn that fast, no matter what kind of rev limiter you have.
i did it once on my b18b. 5th -&gt; 2nd. reved to 8000rpm for a split second. no damage.
Old Sep 26, 2005 | 10:33 PM
JoJO...'s Avatar
lol that hurts
Old Sep 26, 2005 | 10:34 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (JoJo1190)
If your motor still runs, your fine. And lucky I might add. Friend of mine blew up his 20k mile ITR motor like that.
Old Sep 26, 2005 | 10:46 PM
sicky's Avatar
grammer nawzi
Default Re: (komat)
Rev limiter is there to limit your revs (pushing the throttle, holding a gear too long) won't do **** if you mis-shift. It's not like the rev limiter will take your car out of gear for you or press the clutch. Common sense people, where is it?
Old Sep 26, 2005 | 10:53 PM
Mista Bone's Avatar
D Tranny Guru
D15B7 has a 6500 rpm limiter, currently spinning mine to 7500+ rpm with a chip and huge cam.........
It likes it
Old Sep 26, 2005 | 10:58 PM
Kamin's Avatar
Default Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt the rev limiter kick in and drop it back down to whatever is the limiter is</TD></TR></TABLE>
no
this is called a mechanical overrev. there is nothing to prevent this.
Old Sep 27, 2005 | 03:08 AM
EKCRX-Ihadastupidusername's Avatar
Default Re: (Kamin)
I don't know why people get worried by by going 700 RPM above redline. It's not one of GM's 1980's weak as wheezy 4 bangers that top out at 4500 rpm, Honda's, will taking all assfucking you can think of. Well, except the ZC and Y8.
Old Sep 27, 2005 | 11:50 AM
komat's Avatar
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
no
no i wasnt takling about it wont go pass the limiter with a misshift
since he kept on gasing it down for 3-5sec
it should of slowly went back down to whatever the limiter is since
Old Sep 27, 2005 | 11:53 AM
pdiggitydogg's Avatar
Ive never understood how anyone can do this, during normal driving conditions. You have to be just jumping off the clutch
atmosphere
12
Apr 8, 2006 02:02 PM
BOOSTIN1
Apr 26, 2004 06:52 PM
VtecKiDD
Mar 17, 2004 05:36 AM
